I have no idea what this device is. It was in my father's garage. Dad was a T guy, so I'm hoping it is some sort of T item that someone can identify. The overall length is about 10". It does no fold out straight. The two pics show the full open and full closed positions.
Thanks in advance for looking.
Help to identify a tool
otrcman
Topic author - Posts: 366
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
- Attachments
- Mystery tool 3.jpg (59.56 KiB) Viewed 1871 times
- Mystery tool 1.jpg (40.75 KiB) Viewed 1871 times
- Mystery tool 2.jpg (35.95 KiB) Viewed 1871 times
- Last Name: Hatch
Re: Help to identify a tool
Piston ring groove cleaner.
otrcman
- First Name: Dick
Thanks for the fast I.D. Dan. Do you know if it's meant specifically for a Model T, or is it a generic ?
Dick
Dick
It's a mechanic's tool. (Lisle?) The spoke like device has a selection of scraper bits for use with various types of pistons. You loosen the knob and turn the spoked wheel so that the correct bit is in position to use. A stock Model T would use a bit designed for a 1/4" ring groove. The tool is to be used carefully, taking out only carbon, and no metal.
