Generator f Front Bearing
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Mon Jun 21, 2021 6:59 pm
I have taken two generators apart lately that have two bearings in front. The rear bearing acts as a spacer as the shaft shoulder is set back. What's the deal.
Re: Generator f Front Bearing
Post by Mark Gregush » Mon Jun 21, 2021 7:25 pm
You can add up to 5 photos per post, so you may want to combine all into one and if more then 5, add as a reply to keep all in same string. If that brush plate came out of the same generator, maybe post the whole unit showing the case and end pieces.
Plankhill
First Name: Brendan
Last Name: Doughty
Post by Plankhill » Tue Jun 22, 2021 5:29 am
No Not out of the same unit.
Post by speedytinc » Tue Jun 22, 2021 8:10 am
I have rebuit a couple hundred generators. Never seen this.
SWAG: Say Q/C ends up with a batch of scrap armatures where the shaft is machined too far in.(out of tolerence) They rework the shaft using a 2nd bearing as a spacer. Parts made usable. That 2nd bearing could serve no other purpose.
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Tue Jun 22, 2021 8:18 pm
Could that be an example of one of the very early Ford Generators? The F.A. Liberty generator, (or whatever it was) before they went to the standard Ford pattern device?
