Hi,
I cannot figure out how the wire spring is supposed to fasten together. I took apart both headlights and found this spring in front of the reflector instead of behind.
This is how the assembly should look:
I foolishly disconnected the trick wire joint to get the spring wire to fit in the headlight bucket. When I went to check the other headlight, the spring was already apart.
I have searched and cannot find a good image of the spring wire connected together.
The reason that I am working on the headlights is that the bright trim ring fell off and the glass broke. Do I need to secure the trim ring with a sheet metal screw? I have heard that some folks do that.
Thank you, Richard
1926 Headlight Spring
Re: 1926 Headlight Spring
Look at langs. They have a pretty good picture. Try to fix or replace the bad piece, not a 1/2*** patch job.
ifrichard
Topic author - Posts: 20
- Last Name: Harvey
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tourer
Thank you. I was trying to make it much harder and more permanent.
It's just the same way as you would 'hook' your little pinkies together
