What to use for a pressure gauge?
schwabd1
Topic author - Posts: 274
- Last Name: Schwab
I'm working on a speedster and want to use a pressurized fuel system with a hand pump. Where can I get a pressure gauge that will read that low? I'm guessing I want something that reads 0-5 lbs. What should the pressure be on a sealed unit? 1-2 lbs?
Re: What to use for a pressuren gauge?
Couple of old discussions : around 3lbs - sun may increase pressure and don't forget the stock cap is vented
http://www.mtfca.com/discus/messages/29/28768.html
http://www.mtfca.com/discus/messages/11 ... 1286937335
http://www.mtfca.com/discus/messages/33 ... 1376041004
This may be an interesting attachment to include 1-5 psi fuel pressure regulator
https://www.ebay.com/itm/313552564263?h ... Sw96VguCIN
Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
1-2 lbs is good for a hand pump. They make modern low fuel pressure guages. The old vintage ones can get pretty steep in price.
Tim
Tim
TMiller6
- First Name: Thomas
- Last Name: Miller
Look at ATV tire gages on Amazon and places like Dennis Kirk. Typically brass with 0-10 or 0-15 psi scales.
Tom Miller
Been Here Before
- First Name: George John
- Last Name: Drobnock
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: What to use for a pressure gauge?
"Never been there; done that", but could an oil pressure gauge that was calibrated low, work? The Dodges from the 1920's used a low calibrated oil pressure gauge.
John Codman
- Last Name: Codman
Grainger has one that is 0 - 5PSI ( item # 18C790) but it's $35.
