Has anyone used this LANGS vaporizer conversion part ?
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
Post by Dave_Kriegel » Wed Jul 07, 2021 1:04 pm
It supposedly allows use of an NH without punching a hole in the block Anyone use it and could send me a few pictures of how it is installed??
https://www.modeltford.com//item/6299CL.aspx
David Kriegel Mishawaka IN dakriegel@yahoo.com
Re: Has anyone used this LANGS vaporizer conversion part ?
Post by RajoRacer » Wed Jul 07, 2021 1:08 pm
I've installed one - pretty straight forward installation - sorry - didn't take a photo.
Post by DanTreace » Wed Jul 07, 2021 2:43 pm
Found this photo on the web, shows the upper Y-piece, of an older design part, that bolts to the cylinder head. Throttle rod attaches to the lever part and the lower end fits to the NH carb.
This is the newest style design, seems a bit easier in attachment and operation, but haven't any experience with these pieces.
Image 7-7-21 at 2.34 PM.jpeg (31.37 KiB) Viewed 2127 times
hbarbee
First Name: Hurst
Last Name: Barbee
* REQUIRED* Type and Year of Model Ts owned: 1927 Runabout with Pickup Body
Post by hbarbee » Wed Jul 07, 2021 4:48 pm
I recently installed it as part of the whole vaporizer to NH conversion kit that Langs offers.
Attached are pics of the upper and lower ends.
The upper is pretty straight forward. The lower is not. The tabs shown in the Langs picture did not come bent down and it took me a while to figure that out. Also since they did not provide a way to attach it to the carb, I found a small very flat headed bolt as shown. You also have to grind a little off of the area around the vertical post so it does not rub on the carb.
It works fine.
Regards,
Hurst
Dave_Kriegel
First Name: David
Last Name: Kriegel
Post by Dave_Kriegel » Wed Jul 07, 2021 6:13 pm
Langs called in response to a question There are no detailed instructions They suggest I also buy part number 3535B a rod Thanks to all I will try it
hbarbee
First Name: Hurst
Last Name: Barbee
Post by hbarbee » Wed Jul 07, 2021 6:36 pm
You may or may not need the rod. The one they provided with the "kit" did not fit so I bent and reused the one I had on the vaporizer carb.
