Opinions On Front Turn Signal Placement
paddy1998
Last Name: Delaney
* REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
Post by paddy1998 » Sat Jul 10, 2021 2:04 pm
I'm putting turn signals on my touring and looking for advice on front placement.
Eventually I want to lay my hands on a couple of cowl lamps, but that's not in this year's budget. In the meantime I'm going to make use of these bullet fixtures. I'd like to not drill into the fenders (especially since I already have plans to scrap these fixtures.
Each of my headlight rims has a set screw (which drove me crazy the first time I tried open them!). The picture shows the lights mounted to the rims at the set screws.
Thoughts? Too close to the headlights?
Anybody ever done this?
First Name: Henry
Last Name: Lee
Re: Opinions On Front Turn Signal Placement
Post by Henry K. Lee » Sat Jul 10, 2021 2:16 pm
Eric I have always made a small bracket off the bottom of the headlight mount bolts. Works well.
paddy1998
Last Name: Delaney
Post by paddy1998 » Sat Jul 10, 2021 2:27 pm
That was the other place I was thinking of but I thought they might be too low.
Worked for you though, huh?
Last Name: Strange
Post by CudaMan » Sat Jul 10, 2021 2:38 pm
Here is how my 1924 looks with the turn signals positioned as Hank says. IMO, they aren't too low. :)
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Post by JvanMaanen » Sat Jul 10, 2021 2:56 pm
T's set higher than the modern cars, so wouldn't worry about them being too low. Mark's look just right to me. Mark is that a Cuda under wraps next to the T?
Van
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sat Jul 10, 2021 3:12 pm
If they’re not where the “modern moron’s” expect them to be they are basically useless. Mine we where Cuda’s we’re and I don’t believe they did any good there. Don’t rely on them as a safety factor because that’s just in your head. They’ll be ignored as if they weren’t there.
Post by Mark Gregush » Sat Jul 10, 2021 4:16 pm
While I went with bigger lights front and rear, my fronts were mounted in the same place shown above.
Post by speedytinc » Sat Jul 10, 2021 4:22 pm
Thats a cleaner than average set up. Look like the bodies are painted black. Nice.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Sat Jul 10, 2021 5:06 pm
Basically the same place on my ‘27 Roadster. They work well in Los Angeles traffic.
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Sat Jul 10, 2021 5:16 pm
In this day and age, turn signals are largely ignored… period. Placement, brightness, and vehicle make no difference to those that are willing to ignore them. But I use turn signals religiously, driving modern cars or vintage, because it makes things better around good drivers and it can’t make things worse than not having them or not using them.
Keep cranking’
Eric
PS. I am amazed at the number of folks that ignore ambulances and fire engines with full lights and siren.
Last Name: Strange
Post by CudaMan » Sat Jul 10, 2021 6:26 pm
The car next to my T in that picture is the 1971 Plymouth GTX that I used to own. I also used to own a 1971 Plymouth Barracuda convertible that had a 340 six pack, 727 auto, and 3.55 sure-grip swapped in. Now out of the Mopars and have the T and my 1912 Flanders 20 torpedo. :)
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Jul 10, 2021 6:32 pm
I hate the look of modern lights, why not put them inside Ford kerosene cowl lamps.
Post by TXGOAT2 » Sat Jul 10, 2021 6:57 pm
For electrified Ts, buying some modern repro headlight reflectors and mounting turn signal lamps inside the headlight might be an option for the front. LED lights also might be adaptable for this. For the rear, I'd go with dual stock type tail lights, or Model A repro tail lights. The headights are large enough to acommodate a turn signal light without interfering with headlight operation. It's possible to use abrasives to bore a hole in a repro headlight lens, which could be used to mount some type of signal light. For cars with bumpers, I'd attach turn signals to the bumpers.
Post by Mark Gregush » Sat Jul 10, 2021 9:32 pm
Removed by author
paddy1998
Last Name: Delaney
Post by paddy1998 » Sat Jul 10, 2021 10:43 pm
I believe you're right.
That's much better.
Post by TXGOAT2 » Sun Jul 11, 2021 12:11 am
Where ever you put them, they need to be BRIGHT.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Sun Jul 11, 2021 1:32 am
I hate modern crap, stuck on old cars. Especially if no effort is made
to hide it. At the very least, blackout paint could be used to conceal
some discreet moderns. Or one can go on ebay and round up some period
fixtures and restore them, Remember that, ... restoring old stuff because
it is cool ? :lol:
These new LED diodes can be extemely small and extremely bright. Just
by themselves they can be totally unseen until lit up.
Virtus
First Name: Paul
Last Name: Robertson
* REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Post by Virtus » Sun Jul 11, 2021 2:51 am
No missing this old girl's indicators, l.e.d's in the cowel lights and flashing bulbs in the " Winka" cable controlled semaphores!
joe.wal
First Name: Joerg
Last Name: Walther
Post by joe.wal » Sun Jul 11, 2021 6:47 am
If you might think of a relatively small investment: the vendor of my T installed motor bike signals. No holes to be drilled.
1916 Touring
Post by Steve Jelf » Sun Jul 11, 2021 10:35 am
Wherever you put your front signals, they should not be near the headlights. Turn signals too close to the headlights are often difficult or impossible to see.
John Codman
Last Name: Codman
Post by John Codman » Sun Jul 11, 2021 12:06 pm
As I do not drive my T at night, the placement of front directional signals would not be important on my T, but if you do drive your T at night I agree with Steve Jelf. If the directionals are close to your headlights, they are useless.
George Mills
Last Name: Mills
Post by George Mills » Sun Jul 11, 2021 1:07 pm
There is a way to mount a stock small u-bolt over the fender irons and draw up the draw bar part, then mount the regular stock bracket that comes with some bee-hives onto the projecting studs and 2nd nut them in place with a little loc-tite.
I did that on my Hack because I wasn't sure where I wanted them...that was maybe 7 years ago...haven't had desire to move them since...lol
Screen Shot 2021-07-11 at 1.04.33 PM.png (106.34 KiB) Viewed 4731 times
