Opinions On Front Turn Signal Placement
paddy1998
Topic author - Posts: 190
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
I'm putting turn signals on my touring and looking for advice on front placement.
Eventually I want to lay my hands on a couple of cowl lamps, but that's not in this year's budget. In the meantime I'm going to make use of these bullet fixtures. I'd like to not drill into the fenders (especially since I already have plans to scrap these fixtures.
Each of my headlight rims has a set screw (which drove me crazy the first time I tried open them!). The picture shows the lights mounted to the rims at the set screws.
Thoughts? Too close to the headlights?
Anybody ever done this?
- First Name: Henry
- Last Name: Lee
Re: Opinions On Front Turn Signal Placement
Eric I have always made a small bracket off the bottom of the headlight mount bolts. Works well.
paddy1998
That was the other place I was thinking of but I thought they might be too low.Henry K. Lee wrote: ↑Sat Jul 10, 2021 2:16 pmEric I have always made a small bracket off the bottom of the headlight mount bolts. Works well.
Worked for you though, huh?
- Last Name: Strange
Here is how my 1924 looks with the turn signals positioned as Hank says. IMO, they aren't too low.
JvanMaanen
- First Name: Jim
- Last Name: Van Maanen
- * REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
T's set higher than the modern cars, so wouldn't worry about them being too low. Mark's look just right to me. Mark is that a Cuda under wraps next to the T?
Van
Van
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
If they’re not where the “modern moron’s” expect them to be they are basically useless. Mine we where Cuda’s we’re and I don’t believe they did any good there. Don’t rely on them as a safety factor because that’s just in your head. They’ll be ignored as if they weren’t there.
While I went with bigger lights front and rear, my fronts were mounted in the same place shown above.
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Basically the same place on my ‘27 Roadster. They work well in Los Angeles traffic.
ewdysar
- First Name: Eric
- Last Name: D
In this day and age, turn signals are largely ignored… period. Placement, brightness, and vehicle make no difference to those that are willing to ignore them. But I use turn signals religiously, driving modern cars or vintage, because it makes things better around good drivers and it can’t make things worse than not having them or not using them.Charlie B in N.J. wrote: ↑Sat Jul 10, 2021 3:12 pmIf they’re not where the “modern moron’s” expect them to be they are basically useless. Mine we where Cuda’s we’re and I don’t believe they did any good there. Don’t rely on them as a safety factor because that’s just in your head. They’ll be ignored as if they weren’t there.
Keep cranking’
Eric
PS. I am amazed at the number of folks that ignore ambulances and fire engines with full lights and siren.
The car next to my T in that picture is the 1971 Plymouth GTX that I used to own. I also used to own a 1971 Plymouth Barracuda convertible that had a 340 six pack, 727 auto, and 3.55 sure-grip swapped in. Now out of the Mopars and have the T and my 1912 Flanders 20 torpedo.
- Last Name: Humble
I hate the look of modern lights, why not put them inside Ford kerosene cowl lamps.
For electrified Ts, buying some modern repro headlight reflectors and mounting turn signal lamps inside the headlight might be an option for the front. LED lights also might be adaptable for this. For the rear, I'd go with dual stock type tail lights, or Model A repro tail lights. The headights are large enough to acommodate a turn signal light without interfering with headlight operation. It's possible to use abrasives to bore a hole in a repro headlight lens, which could be used to mount some type of signal light. For cars with bumpers, I'd attach turn signals to the bumpers.
Removed by author
paddy1998
I believe you're right.Henry K. Lee wrote: ↑Sat Jul 10, 2021 2:16 pmEric I have always made a small bracket off the bottom of the headlight mount bolts. Works well.
That's much better.
Where ever you put them, they need to be BRIGHT.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
I hate modern crap, stuck on old cars. Especially if no effort is made
to hide it. At the very least, blackout paint could be used to conceal
some discreet moderns. Or one can go on ebay and round up some period
fixtures and restore them, Remember that, ... restoring old stuff because
it is cool ?
These new LED diodes can be extemely small and extremely bright. Just
by themselves they can be totally unseen until lit up.
it is cool ?
Virtus
- First Name: Paul
- Last Name: Robertson
- * REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
No missing this old girl's indicators, l.e.d's in the cowel lights and flashing bulbs in the " Winka" cable controlled semaphores!
joe.wal
- First Name: Joerg
- Last Name: Walther
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring
If you might think of a relatively small investment: the vendor of my T installed motor bike signals. No holes to be drilled.
1916 Touring
Wherever you put your front signals, they should not be near the headlights. Turn signals too close to the headlights are often difficult or impossible to see.
John Codman
- Last Name: Codman
As I do not drive my T at night, the placement of front directional signals would not be important on my T, but if you do drive your T at night I agree with Steve Jelf. If the directionals are close to your headlights, they are useless.
George Mills
- Last Name: Mills
There is a way to mount a stock small u-bolt over the fender irons and draw up the draw bar part, then mount the regular stock bracket that comes with some bee-hives onto the projecting studs and 2nd nut them in place with a little loc-tite.
I did that on my Hack because I wasn't sure where I wanted them...that was maybe 7 years ago...haven't had desire to move them since...lol
