Miller head update
Model T Tom
Topic author - Posts: 430
- First Name: Thomas
- Last Name: Butterworth
- * REQUIRED* Type and Year of Model Ts owned: 1911 speedster
Miller head update
Moving ahead nicely. We expect to get 6.25 -1
- Last Name: Tannehill
- Board Member Since: 2002
Re: Miller head update
Very cool & interesting
Model T Tom
They will available in Aluminum and cast iron.
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Do you have any idea on a price point yet?
Brad
Brad
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
One of the biggest drawbacks to Model T high performance heads is shrouding around the intake valves. Since this is a new project, it would be nice to see the chamber core have an undercut around the walls adjacent to the intake to reduce this problem.
AndyClary
- First Name: Andrew
- Last Name: Clary
A little late now, but the Riley head was huge around and over the valves for better flow.
Andy
Andy
Model T Tom
Up date.
Model T Tom
dmdeaton
- First Name: Danny
- Last Name: Deaton
Tom
How soon till finished product?
Model T Tom
Don't know the gentleman making them is busy in his shop. He works on it when he gets time .
I would be interested in an iron unit if you are taking names.
Ill keep an eye out here for your progress.
Model T Tom
Water jacket
Model T Tom
John bevardos
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Sign me up !
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Model T Tom
Almost ready for the first prototype
Model T Tom
Update
I will admit that I was a skeptic in the beginning, but must make amends. Very impressive progress, and kudos for supporting the hobby in this fashion.
Model T Tom
Thank you Scott I appreciate that.
Model T Tom
I need to get an idea how many might be interested. Helps to proceed
Model T Tom
Thinking of making a stock looking low head with same combustion chamber chamber as the Miller. Any interest ?
Yes. How about a high head? As long as it is iron, not aluminum.Model T Tom wrote: ↑Sat Jun 26, 2021 11:54 amThinking of making a stock looking low head with same combustion chamber chamber as the Miller. Any interest ?
Model T Tom
Not at this time. Plenty of high heads out there. Aiming for something different.
Bob McDaniel
- First Name: Bob
- Last Name: McDaniel
Interested as long as it looks close to stock on the outside.Model T Tom wrote: ↑Sat Jun 26, 2021 11:54 amThinking of making a stock looking low head with same combustion chamber chamber as the Miller. Any interest ?
Yes, but none in iron. I wont run aluminum. The increased water capacity would be an advantage. You would have the ONLY iron hi head. I would steer all my people to it. Consider it for later runs.Model T Tom wrote: ↑Sat Jun 26, 2021 12:36 pmNot at this time. Plenty of high heads out there. Aiming for something different.
Pruis makes a great hi head in aluminum, but, not iron. You would be the only one on the market.
Les Schubert
- First Name: Les
- Last Name: Schubert
John
The first run of Prus heads was in iron. I committed and got one!
At my stage I don’t need any more, but this is a interesting project!
I missed that option. I tried to get a Pruis head in iron. He has given that up due to porus casting issues.Les Schubert wrote: ↑Sat Jun 26, 2021 3:58 pmJohn
I have found a few second hand lizard heads to run. They had porosity issues also, but were repairable/usable.
For future motors, personal & customers, a high iron head would be ideal with this compression ratio/chamber design.
If not available, a low head may have to do. As long as its IRON.
Kevin Pharis
- Last Name: Pharis
Lookin great Tom! Keep up the excellent progress, I hope to see pics of raw castings soon
Les Schubert
- First Name: Les
I’ve had better luck getting good iron castings than aluminum ones when I was doing my T block project.
Model T Tom
This is a sample the quality heads he produced. Having 1 aluminium and 1 iron head made to test.
Model T Tom
Here is a model A Miller head in iron. Quality work only.
Model T Tom
Sorry Winfield head
Hudson29
- First Name: Paul
- Last Name: O'Neil
I would be interested in a head that looks stock. I have a Z head on one car that works well. The second T could use a bit more pep . . .Model T Tom wrote: ↑Sat Jun 26, 2021 11:54 amThinking of making a stock looking low head with same combustion chamber chamber as the Miller. Any interest ?
paul
CamMan
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Tom,
The Prus, Z and reproduction Rajo heads all have 5 to 5.3 compression ratio but claim anywhere from 6 to 8. Determining an accurate number is not rocket science. What is the combustion chamber volume and "true" compression ratio on this Miller head? See http://mtfctulsa.com/Tech/head_design.htm
Model T Tom
A test chamber was CNC cut and CC'D to get an accurate ratio.
Dan McEachern
- First Name: DAN
Seems the solid model should have given a pretty exact volume- no need to machine a dummy?? So what is the chamber volume?
Model T Tom
Chamber volume is 180.
Dan McEachern
- First Name: DAN
4" stroke, stock bore and piston volume of 52.25 cc, that comes out pretty close to 6:1
Model T Tom
Model T Tom
First 2 head's poured today. They will be shaken out tomorrow and we will see what we got.
dykker5502
- First Name: Michael
- Last Name: Deichmann
For that pricerange - I may be interested in one.
(Denmark)
(Denmark)
Ford Model T 1914 Touring
John bevardos
Put me on the list
Model T Tom
Model T Tom
One more
Model T Tom
Better picture
Michael Peternell
- Last Name: Peternell
Bottom and top side photos don't seem to match?
Michael
I was wondering the same thing and wonder now if it isn't a function of camera angle. As an amature machinist I could see where the gasket side would be molded to a machinable profile with the water jacket being above it and squared off. All views have so little depth of field that within an inch or two the far side is shrunk beyond the line of sight. Look at the underside view and magnify it while looking at the right/forward corner and see if you don't happen to see what appears to be (?) a squared off profile lurking below/beyond the seal surface.
A 3/4 view would be most interesting and at least dispel confusion
At any rate, pretty nice looking castings with an absolute minimum of obvious porosity
Michael Peternell
Just can't be unless there's a flat top hiding the rest? Not trying to be any sort of expert! I'm definitely on the other end that!Scott_Conger wrote: ↑Wed Jul 14, 2021 8:54 pmMichael
Joe Voller
- First Name: Joe
- Last Name: Voller
- * REQUIRED* Type and Year of Model Ts owned: 1924 pickup 1922 centerdoor
I would be interested in a cast iron head high preferred but would buy a low until the highs come along.
BHarper
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Hi Tom,
Wow, that Miller style head is Gorgeous! Bravo!
I would buy one IF it were cast iron. I am not keen for an aluminum head.
Wonderful work and I wish you continued success with this project, Bill
Bill Harper
Keene, New Hampshire
Model T Tom
Better pictures
Thanks Tom
that's exactly what I had imagined was lurking!
that is one beautiful casting
Looks like #3 spark plug hole is centered between the valves. The others are over or closer to the intake valves. Why is that? Optical delusion, experiment, special clearance?
Model T Tom
Optical illusion
Michael
you a believer yet?
you a believer yet?
Michael Peternell
Yup! My bad!
