Brakes for 25 roadster
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Tue Jul 20, 2021 8:06 pm
Need brakes and looking at Lang's there are two types. One is a single shoe that is lines and the other is a two piece that is lined. Which is best and why? Need to order tomorrow!
Re: Brakes for 25 roadster
Post by Allan » Tue Jul 20, 2021 9:41 pm
Dick, the two piece ones require much fettling to get them anywhere near fitting. They are to be avoided if you cannot be bothered. The one piece variety fit much better. I believe the originals and these replacements were/are made in one piece as an aid to ease/ consistency in production. Both are prone to breakage in use as they wear and have to flex more. Cast iron does not flex well, so to prevent them breaking in an in-opportune place, i use a hacksaw to cut half way through the loop at the pivot bolt. That way if they do break, it will be at a point of no consequence. They have lugs for springs on both sides of the shoe so that they do not get tangled up if they break. Others don't bother with the saw cut.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Wed Jul 21, 2021 7:00 am
The one piece shoes are the way to go.
Stephen
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Wed Jul 21, 2021 8:31 am
I too have the one piece assembly and very pleased with them. They are complete with bonded friction material that
matches the 8” drum perfectly.
Alan in Western Australia
Post by speedytinc » Wed Jul 21, 2021 8:57 am
I just installed a set. They did require some narrowing in places. Not the same width all the way around. Way better than the 2 piece.
The 2 piece unis seem to want to tip out & are held in place by drum contact.
Post by Mark Gregush » Wed Jul 21, 2021 11:19 am
When installing one or two piece brake shoes, put the springs on the back side of the shoes. This tends to pull the shoes back against the backing plate. Putting the springs on the front tends to pull them away.
Post by speedytinc » Wed Jul 21, 2021 11:26 am
True, I do that.
When hunting down spots where there is rubbing, I find a light coat of flat black spray paint inside the drum helps pin point the spot.
Remove when done with a little gas.
DickC
First Name: Dick
Post by DickC » Wed Jul 21, 2021 5:01 pm
Thanks everyone. I ordered the one piece set.
