Early top fasteners
Dropacent
Last Name: Morsher
Early top fasteners
Post by Dropacent » Sun Jul 25, 2021 3:18 pm
Thanks to keith, I’ve corrected my post. Here are some samples, I’m sure there are others. The very early T and pre-T used similar fasteners to the Murphy, but different. I think appropriate for very early T, and certainly pre-T autos. I don’t have an example of a Murphy brand to show, but are the same and interchangeable with the Common Sense brand. Then, Lift-the-Dot , which is a brand and encompasses other fasteners, also called lift-the-dot, and finally post snaps. These also likely have a name, don’t know what it is, but generally these last two are common in the model A Ford and that era.
First Name: Keith
Last Name: Townsend
Re: Early top fasteners
Post by KWTownsend » Sun Jul 25, 2021 4:06 pm
Those on the left are Burco Fasteners.
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 4:08 pm
Thanks Keith!
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Jul 25, 2021 4:30 pm
Top left early hour glass Murphy Fastener. Up to '11
Top right oval base Murphy fastener. '12 - ?
Middle left original Murphy Fastener
Middle right reproduction double height Murphy fastener.
Bottom left original Murphy fastener.
Bottom right reproduction Murphy fasteners have screw head on the underside.
Keith
Last Name: Wrenn
Post by TWrenn » Sun Jul 25, 2021 4:38 pm
My '11 Torpedo has fasteners similar to the Murphys pictured above, except they say "dot" on them. Not to be confused with "lift-a-dot".
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Jul 25, 2021 4:42 pm
Tim,
Like this?
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 5:58 pm
I’ll post some great stuff I stole off the interweb. Keep in mind, different folks have different names for some of this stuff, so be careful. There were regional differences, nicknames, etc, it’s a good resource to identify a lot of neat hardware used on our old cars.
Dropacent
Last Name: Morsher
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 5:59 pm
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 6:00 pm
[/attachment]
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 6:01 pm
Dropacent
Last Name: Morsher
Post by Dropacent » Sun Jul 25, 2021 6:02 pm
Post by RajoRacer » Sun Jul 25, 2021 6:07 pm
Well, that's "educational" as all hell !!! Thanks Tim !
Last Name: Wrenn
Post by TWrenn » Sun Jul 25, 2021 6:12 pm
Tim,
Like this?
Now that Steve and the other Tim bounced my first response Keith I'll try again! :lol:
The answer to your question is "yup".
And also, I have no idea if they are "original T" or not. Maybe the "other Tim", my good friend i also call Tim I, will have an idea!
Tim II
Post by Rich Eagle » Sun Jul 25, 2021 6:25 pm
What a nice collection of information. Here are a couple variations on the Murphy as well as one with an anchor symbol on it. I'm sure there were a lot of companies making their own version.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Jul 25, 2021 11:43 pm
All of these fasteners were on one unrestored original 1911 touring:
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Jul 25, 2021 11:46 pm
These too.
I'm sure these was a bin of single height, and a bin on double height with all brands mixed in together...
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sun Jul 25, 2021 11:50 pm
Here is a nifty little set of replacement Anchor fasteners I picked up a while back:
Keith
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Jul 26, 2021 12:08 am
Early Anchor fasteners had an A. I'm not sure if the Anchor picture came later.
At some point Murphy and Bruco joined:
The Murphy Fastener was patented May 7, 1907:
Murphy Fastener patent 1907.pdf
(176.96 KiB) Downloaded 82 times
The Bourque Fastener was patented Jan 1919:
Murphy fastener patent 1917 Bourque.pdf
(134.5 KiB) Downloaded 91 times
If you so a google search you can read all about the 1914 lawsuit between Murphy and the Metal Stamping Company...
Keith
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Jul 26, 2021 12:39 am
Oh and the "glove fasteners" are Anzo fasteners. They are the predecessor to what we call today a "snap".
The stud of the Anzo passes through a hole in the side curtain and the top flap "snaps" onto the stud, sandwiching the side curtain in place.
Upholstery Mike
First Name: MICHAEL
Last Name: FRANCIS
Post by Upholstery Mike » Mon Jul 26, 2021 9:32 am
Thank you for posting. I've been collecting so many of those fasteners and now I know the REAL names for the ones I didn't already know.
Post by Original Smith » Mon Jul 26, 2021 11:58 am
I believe that fastener with the DOT on it is a newly made variety. I've never seen an old stock common sense fastener with a flat top. I have hundreds of original common sense fasteners to prove it.
Upholstery Mike
First Name: MICHAEL
Last Name: FRANCIS
Post by Upholstery Mike » Mon Jul 26, 2021 12:33 pm
I believe you're correct Larry. I have at least 5 different original styles I've collected and they don't say dot.
