New cam bushing tool
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Wed Jul 28, 2021 4:07 pm
Haven’t posted an engine build update in a while so I think I’ll start with this. I’m rebuilding the engine for my 27 closed cab TT. Doing most of the work myself I needed a tool to properly ream out the rear cam bushing in line with the front bearings. With the help of my local machine shop and a very nice guy in Washington who supplied measurements and great pictures, this tool was born. Makes reaming the rear bushing super easy and precise. Who knows how often I’ll actually need to use it but at least I have it in my arsenal now! Simple yet effective. Shaft turned down to barely slide through the bearing journals with ease. Small stub reamer held in by a set screw. The end of the shaft was machined so that it can easily be turned by hand with a wrench, length of rod stock or be chucked up in a drill. It took more time to install the bushing than to actually ream it out.
Brad
Re: New cam bushing tool
Post by Scott_Conger » Wed Jul 28, 2021 6:37 pm
Nice job, Brad
I made one for myself and it was definitely worth the time and effort
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Jul 28, 2021 6:47 pm
Nice Work Rookie!
kelly mt
Last Name: Kelly
Post by kelly mt » Wed Jul 28, 2021 7:22 pm
Nice work.
John Illinois
Last Name: Burgett
Post by John Illinois » Thu Jul 29, 2021 9:00 am
I made one also. Used some aluminum round stock which made for easy machining. Not as durable as steel but fine for the purpose.
John
Post by RajoRacer » Thu Jul 29, 2021 10:31 am
Copy of a K.R. Wilson reamer of mine that Brad utilized dimensions from.
Jeepbone1
First Name: Brad
Last Name: Kirtner
Post by Jeepbone1 » Fri Jul 30, 2021 11:15 pm
Thanks for commenting Steve. Without your help and pictures I’d be lost in the sauce! This tool really takes the build to the next level.
Brad
Post by RajoRacer » Fri Jul 30, 2021 11:18 pm
You are most welcome, my friend !
rlaplander
Last Name: Laplander
* REQUIRED* Type and Year of Model Ts owned: 1926 roadster
Post by rlaplander » Tue Aug 03, 2021 4:34 pm
Any chance someone has one of these to sell or know where they do off hand? I won't need it until next year, but it pays to be ready and I don't have anyone who can make one.
