Vaporizer Display
hbarbee
Topic author - Posts: 12
- First Name: Hurst
- Last Name: Barbee
- * REQUIRED* Type and Year of Model Ts owned: 1927 Runabout with Pickup Body
Vaporizer Display
After installing the Holley NH conversion kit from Lang's, I restored the Vaporizer and decided to keep it as a display piece. Attached is a picture. Also, if I ever sold the '27 Model T, then the new owner may need it if they wanted to go back to it for some reason.
I was wondering which is more common, the Ford labeled unit like this one or the Holley version?
Hurst
Hurst
Re: Vaporizer Display
That one, which is the Holley. The other one was the Kingston, which is way less common.
The Vaporizer had both "Ford" and/or "Holley" name tags - Kingston Regenerator was a different animal !
- Last Name: House
Steve is right. Holley production couldn’t keep up with Ford T s in 1927 so an agreement was reached allowing Ford to copy the Holley design and affix their own brass ID tag.
Same with the NH, some have Holley some have Ford tags.
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
Some of the 1927 Model Ts came with Kingston vaporizers, but they were B-1 Gasifiers, not Regenerators. The Kingston Regenerators were a model made for the aftermarket and were advertised already in 1924 in the Ford Owner and Dealer magazine.
1922 Coupe , 1926 Touring
Appreciate the correction, Jim !
Erik Barrett
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Hanging on a wall is what vaporizers do best.
Chris Barker
- First Name: Chris
- Last Name: Barker
All fine, but was the conversion worth doing? Does it make any difference?
Duey_C
- First Name: Duane
- Last Name: Cooley
Gorgeous!
They do work when good.
