'26-'27 Brake cam dimensions
Mark Nunn
Topic author - Posts: 1287
- Last Name: Nunn
I need to replace my brake cam bushings and need to decide if I need to replace the cams too. Does anyone know what the thickness of the cam head should be? I can measure the shafts for wear but I don't have a reference for cam thickness.
Scott C.
- Last Name: Clements
Re: '26-'27 Brake cam dimensions
I measured a set of new ones at .740" and a nice original one at .752".
ModelTGal
- First Name: Jennifer
- Last Name: Pierce
Anyone know if the new pinned brake cams are providing good service? I hear the earlier replacements were splined and didn’t do well…
Jennifer
Jennifer
Don't know yet, ask in a few years!
In light of the problems with the two piece repops, I would be chucking the shaft in the lathe, machining a substantial grove around the shaft and cam interface, and adding a substantial weld to further unite the two components.
