Seeking Information
Seeking Information
Post by RajoRacer » Fri Aug 13, 2021 12:09 pm
Has anyone found a source for a low profile 12 volt dual filament bulb ? No need for the debate over 6v vs. 12v - doing the socket conversion on a stock '24 - '27 cup style tail lamp which a 6v dual filament bulb IS available - just looking for the same in a 12v prior to disturbing a stock lamp socket.
Re: Seeking Information
Post by Original Smith » Fri Aug 13, 2021 1:15 pm
Steve:
I have NO proof on this, but I've found several original appearing late style license plate brackets with late style socket, almost identical to the headlight style. My question is did Ford make these as a replacement after Model T production stopped. I understand your needs, and can't help you, but I'm using a Snyders cowlight cowl light bulb in mine which is 6Volt. For some reason they used staggered pins, so I have to file the off set pin down to accommodate there mistake! Perhaps they make a 12V version too?
Fordwright
First Name: Greg
Last Name: Popove
Post by Fordwright » Fri Aug 13, 2021 1:19 pm
Something here might possibly help:
https://www.ledlight.com/ledlight-6-vol ... talog.aspx
Post by DanTreace » Fri Aug 13, 2021 1:20 pm
Don’t think you’ll find an incandescent 1157 (tail and stop filaments) shorter to fit inside the housing and lens as they are all around 2” high.
But these LEDs would fit, much lower height and brighter and lower power use!
Post by RajoRacer » Fri Aug 13, 2021 1:29 pm
Much appreciate the input fellas !!! Didn't want to "punch out" a perfectly good original s.c. socket without sourcing a suitable 12v bulb to fit !
Post by Original Smith » Sat Aug 14, 2021 10:54 am
Steve: Snyders has a low profile 12 volt bulb, but is a staggered pin like I mentioned above. BUT, you have to find a late style Ford made license plate bracket like I mentioned above. You will need a two prong retractable contact plug to use it. I have one on my pickup, and you've seen it. Just looking at it, you can't tell the difference. If you want a plug I have one for you.
