Carburetor Identification
Devon
Topic author - Posts: 2
- First Name: Devon
- Last Name: Hall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
Hello all! I recently acquired my first Model T, a beautiful 1926 Roadster. I don't recognize the carburetor or know anything about it. Does anyone recognize what it might be? Thanks!
Re: Carburetor Identification
Pretty sure it's off a Kohler or similar lawn tractor engine.
Ruxstel24
- Last Name: Hanlon
Definitely a much more modern carburetor than was available in “the day”....
But I just have to ask, how’s it run ?
- Last Name: Strange
http://www.mtfca.com/discus/messages/59 ... 1477323576
http://www.mtfca.com/discus/messages/11 ... 1273173491
http://www.mtfca.com/discus/messages/17 ... 1302987864
Keep looking and you're likely to find a fuel pump, too.
welcome to the affliction!
Devon
- First Name: Devon
- Last Name: Hall
Well that is certainly not the answer I was expecting. Thanks everyone for the info, I'll certainly be switching it out!
No fuel pump needed for the "Improved" model with cowl tank.
Steve...even with a Walbro?
I've only seen a couple of them and I know they needed the pump...neither was an improved car, but I'd expect that the float valve is so small that it wouldn't likely perform well without one even with the tank mounted higher. With so little experience with them, I'm quite possibly wrong, but I've never heard or read of one performing on a T without help.
That's probable - never had one to play with.
