help can someone show me a picture of what the support for my truck seat should be. i have the original springs, but all there is to support the springs is the netal frame around the front, but at the back there is just a 1 inch thick by 4 inch wide board that is attached to the cab with 2 hindges.
john
26 model tt truck seat
Topic author - Posts: 9
- Last Name: hislop
- * REQUIRED* Type and Year of Model Ts owned: 1926 ford model tt truck
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Re: 26 model tt truck seat
Is it a closed cab or C cab? Here’s what the closed cab seat frame looks like.
Brad
Brad
- Last Name: hislop
great picture thanks
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
There should be wood completely under the seat springs but not attached to the springs. I have a C-Cab and I used plywood. I believe it's hinged so you can lift it up and get to the back storage area.
R/Mark
R/Mark
- * REQUIRED* Type and Year of Model Ts owned: 25 TT
If you have the board and hinges- that is bonus, as they seem to be gone most of the time. The board and hinges are for the tool box lid under the seat.
