Will an open spool fit on a housing that was made for a closed spool? I see the opposite will not fit. But I have a later spool and I was wondering if it would fit on an earlier housing.
Rear axle
greenacres36
Topic author - Posts: 164
- First Name: Brian
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
Re: Rear axle
Yes. The distance between the 2 faces are the same. You will have to use the later thrust bearings.(open spool)
greenacres36
- First Name: Brian
Re: Rear axle
Thank you so much. I was measuring the two and I thought it would work. I am a machinist so I make my own modern bearing spools. I could alter my dimensions a little bit to make it work if I had to.
Craig Leach
- First Name: craig
- Last Name: leach
Re: Rear axle
Brian,
If you have any junk axle housings the tube works good for the spacers.
Craig.
Craig.
