26-27 rear fender
Brent
First Name: Brent
Last Name: Coil
* REQUIRED* Type and Year of Model Ts owned: 1914 1917 1926 1927
26-27 rear fender
Post by Brent » Sun Aug 29, 2021 4:22 pm
It is time to do some repair on the ford. I need to remove the rear fenders. My question is about the bolts from the bracket into the body. Do these have a nut on the inside? I removed the rear seat bottom but can't see where the bolts come thru. I am hoping that these just thread into the body. I really don't want to remove the upper rear seat and the fabric covered side panel. Any info would be great.
Brent
ModelTWoods
First Name: Terry
Last Name: Woods
Re: 26-27 rear fender
Post by ModelTWoods » Sun Aug 29, 2021 4:35 pm
As an owner of a 27 coupe, I'm pretty sure everything is nut and bolt. No blind nuts to my recollection.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Sun Aug 29, 2021 6:15 pm
My 27 coupe has blind nuts for the bolts holding the fender mount brackets. The rest are bolt and nuts.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
Board Member Since: 2006
Post by TMiller6 » Mon Aug 30, 2021 3:02 pm
The 26-27 Fordor and Touring bodies have weld nuts inside the body.
Tom Miller
Post by Norman Kling » Mon Aug 30, 2021 6:38 pm
I have a touring, and a roadster. Both have nuts pressed and riveted into the body. You might need some wd40 or penetrating oil to get them started, or the nuts might break loose. They are behind the upholstery in the touring, so if you need to put a nut on the inside with a washer, it won't show, however, hopefully, you can get at least some of them in so that they hold the fender from moving out of place.
Brent
First Name: Brent
Last Name: Coil
Post by Brent » Sat Sep 04, 2021 4:27 pm
Good news. The bolts holding the fender bracket screw into a threaded section attached to the inside of the body. See attached photo. Sorry had to rotate pix to get it to attach
