12 volt Alternator?
Topic author - Posts: 2320
- Last Name: Juhl
12 volt Alternator?
Does anyone know who makes the 12 volt alternator that is a direct replacement for the gear-driven six volt generators on later Model T's? I know the vendors sell them but wonder who they get them from?
Re: !2 volt Alternator?
Be aware of high failure rates. 1) the gear is pinned with a C pin. They tend to shear & fall into the motor. 2) They need good air flow to cool. Without a fanned pulley & the obstruction from the mount, they run hot & can burn up. A buddy had one go bad. It let the smoke out of the generator wire to the firewall & switch. Really ugly.
You can run a stock T generator. Just reset the output to 1/2. It doesnt care what voltage its charging.
You are working real hard to change your T to 12V because of a poor starter. Its the starter, not your high compression head.
Easier & cheaper : 8V battery. Every thing will work on 8V. No other changes necessary, maybe lower generator output. 8V will compensate for that weak starter.
- Last Name: Juhl
My car has no generator or alternator and runs a 12 volt geared starter. The Hot Shot charger from John Regan keeps my 12 volt odyssey battery charged at 90+%. I’m researching for a friend who wants to know his options before deciding which way to go. I appreciate you sharing the potential problems with the alternator....those are the things he needs to know.
George Hand
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
I needed one bad a couple years ago, Langs were on BO, Macs had one & I bought it. I think they come from Buckeye Auto Electric in OHIO, they use a core with an internal fan so they should last longer that the Texas T alternators that used a older Delco core that was made for an External Fan. George.
Or, Heaven Forbid, put a generator on the car. So long as you're not buying a $65 Krylon rebuild off of eBay and stick to known members/vendors, you can put a piece of equipment on your car which will pretty much outlast you, and not look like something that came off of a Kia.
Nunsio1
- Last Name: Monticciolo
- * REQUIRED* Type and Year of Model Ts owned: 1924 C Cab truck
Tim, just ordered my replacement 12 volt alternator from Buckeye Antique Auto Electric $235.00 — they supply Langs, Snyders’s etc.
John Monticciolo
Oscoda Michigan
1924 C Cab
John Monticciolo
Oscoda Michigan
1924 C Cab
BTW the langs unit has a "texas T parts" name casting.
Cap
- First Name: Cap
- Last Name: Weir
- * REQUIRED* Type and Year of Model Ts owned: 24 & 25 C Cab
My Texas T 12 Volt Alt has been running from ~2010.. no problems.. Put it in so I could run Christmas lites off of an Inverter.. Left it and the Inverter in the TT.. Handy
Cap
Cap
HalSched
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
In aprox 2000 I installed a Nissan alternator on my Fordor and have had "0" problems.
HalSched
- First Name: Hal
Belt on px side. Oil pump in gererator hole for pressure mains. AC compressor on Px side and alternator mounted on top of compressor. All riven with one serpentine belt. Works great!
Cap
- First Name: Cap
- Last Name: Weir
I'd love to see a pic of that install!..
Wife wants AC in her T (yet to be purchased).. I'd like to also see the condenser mount..
Cap
