Connecting rods
Lee_downunder
First Name: Lee
Last Name: Taylor
* REQUIRED* Type and Year of Model Ts owned: 1915 run about. 1926 roadster
Board Member Since: 2014
Connecting rods
Post by Lee_downunder » Fri Sep 03, 2021 1:55 am
I have to cut and weld model A and model T rods together. Where is the best place to do it Near the big end or small end or in the middle.
Re: Connecting rods
Post by TXGOAT2 » Sun Sep 05, 2021 12:21 am
I'm not sure it would matter. What are you building?
Lee_downunder
First Name: Lee
Last Name: Taylor
Re: Connecting rods
Post by Lee_downunder » Sun Sep 05, 2021 9:50 pm
A friend bought 2 bumac cranks from snyders but when they arrived the journals were model a size. I have line bored the block and rebabitted and burned to suit. You used to be able to get egge pistons to suit but not now I believe. Therefore I need to cut the model a rods and weld on part of a t rod to get the right t Gurgaon end and thr right length. I think Les Schubert has done this before but I don't know how to get in touch with him.
flatbroke3
First Name: harold
Last Name: musolf
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
Board Member Since: 2010
Re: Connecting rods
Post by flatbroke3 » Tue Sep 07, 2021 9:44 am
I believe that Scat makes a rod that is model A on the big end and model T on the small end. I will look thru my notes to verify.
Harold
Lee_downunder
First Name: Lee
Last Name: Taylor
Re: Connecting rods
Post by Lee_downunder » Tue Sep 07, 2021 10:15 pm
Thank you for your reply. I look forward to see what you find.
Re: Connecting rods
Post by Mark Gregush » Thu Sep 09, 2021 10:09 pm
you might get more help posting on the general forum, this section is for questions about the site, not cars.
