Change from distributor to the standard commutator
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Post by jaybee47 » Fri Sep 10, 2021 11:37 pm
How difficult will it be to return to a conventional commutator from a distributor? Is it simply removing the distributor and alternator and installing a generator and timer along with new wiring and coils and coil box?
jsaylor
Last Name: Saylor
Re: Change from distributor to the standard commutator
Post by jsaylor » Fri Sep 10, 2021 11:50 pm
Alternator can be used with coils. Do you have a working magneto?
Post by Allan » Fri Sep 10, 2021 11:57 pm
If you have a coilbox, all you need is available from the vendors, but I would go to one of the coil rebuilders for coils rather than buy new ones.
There are alternative timers available, mechanical ones like roller or Anderson flapper style, and electronic ones. Your choice, your expense.
Others will have other ideas.
