firestone split rim
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
firestone split rim
Post by hah » Thu Sep 23, 2021 1:50 pm
Greetings all!
Am requesting information on firestone split rims. What I need is the dimensions of the clasp which holds rim together. It is two pieces, one is a rectangle and the other is an arrow which pivots on a pin.
Thamks,
John.
Last Name: Humble
Board Member Since: 2006
Re: firestone split rim
Post by Humblej » Thu Sep 23, 2021 2:42 pm
This should help you out. Play with your printer scale to get the ruler to measure right and you will have a full scale template.
hah
Last Name: hardiman
Post by hah » Thu Sep 23, 2021 8:55 pm
I don"t know how to do that. But, will give it a whirl.
John.
hah
Last Name: hardiman
Post by hah » Tue Sep 28, 2021 4:44 pm
No way, printer scale! Can't get it done. Any others have a thought?
Post by speedytinc » Tue Sep 28, 2021 5:05 pm
Scale it manually. Put a measuring device to the ruler shown. Do some division for a conversion ratio. On my monitor the 2" ruler is 2.050" Near enough 1 to 1. So the bar is about 2 3/3 long. The lock is just under 1.75" long
hah
Last Name: hardiman
Post by hah » Tue Sep 28, 2021 6:02 pm
I'm a genius! John and Jeff much appreciated. Many thanks.
