what spark plugs should you run on a Ricardo head ? model A ?
tom
Ricardo head spark plugs
Re: Ricardo head spark plugs
From an old discussion
Users http://www.mtfca.com/discus/messages/70 ... 1510626132
Theory http://www.mtfca.com/discus/messages/59 ... 1467743860
S/B 1/2" pipe threads - T plugs. If you want some different heat range plugs, 14mm adapters with long reach plugs. A range of plugs is available. I believe datsun Z were the perfect length to use with adapters. I run long reach platinum plugs. Call me if you like.
