Well, this explains the weird noise…
Topic author - Posts: 235
- First Name: Chris
- Last Name: Bamford
Less than a mile from the end of a 560 mile weekend, I heard a ‘ringing’ sound from the engine room, possibly right front. It was reminiscent of the sound of a wet fingertip circling the rim of a wine glass. Not real loud but plenty disturbing.
Turns out I could hardly have asked for an easier outcome — I have a serviceable armature on the shelf and we should be generating again soon after a good cleaning and adjustment.
Strangely, the armature and stub both spun freely in the housing; I have no idea what prompted the shaft to snap as it did.
Re: Well, this explains the weird noise…
Another "never seen this before"
I agree. I've never heard or seen that. I can't imagine why it would break cleanly like that.
Model T's typically do strange, unusual things don't they?
- First Name: Kevin
- Last Name: Matthiesen
The failure at the front generator bearing could have been caused by a slight misalignment between the front generator bracket and the front mounting bracket, or between the generator main body and front mount, over a long time.
- First Name: David
- Last Name: Dewey
and helped along with the undercut for the bearing. I'd say you were very lucky, as if it had broken on the other side of the bearing the gear would have made a mess in the engine!
T'ake care,
David Dewey
David Dewey
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Like the old farmer said when his horse died "I don't understand it. He never did that before".
- First Name: Adam
- Last Name: Doleshal
Slightly bent shaft that was crashing against the large timing gear and flexing slightly until it work hardened, crystalized and broke.
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Now repair the old armature, find a bad armature, press out both shafts and press in the replacement. I have never done it but it can be done.
