Fastening Seat Springs to Belt Rails
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Fri Mar 22, 2019 11:31 am
Would someone who has experience fastening the seat back springs to the belt rails on a 1923-25 Touring car please let me know how they did it, including the position of the springs?
Altair
First Name: David
Last Name: Menzies
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring and 1915 Touring both Canadian models
Board Member Since: 2012
Re: Fastening Seat Springs to Belt Rails
Post by Altair » Fri Mar 22, 2019 12:02 pm
There is a tool called a Hog tie for fastening the springs try Langs[attachment=0]DSC01039.JPG
Last Name: Gregush
Post by Mark Gregush » Fri Mar 22, 2019 12:18 pm
The hog rings are for attaching the material to the springs that can be taken out. Most all the Model T open cars used a channel in the bottom spring to clamp the fabric. The back rest spring would be attached with a strip(s) of material or there would be little bent metal hangers that are screwed to the belt rail. The bottom of the back rest spring is not attached, it just hangs there. Then the padding and cover are attached to the belt rail. The photos are of a 1920ish back rest spring clips.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Fri Mar 22, 2019 2:53 pm
Thanks. Could you tell me the position of the back rest in relation to the belt rail? How Much lower than the belt rail should it be positioned, both front and rear seats.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Fri Mar 22, 2019 11:39 pm
Can someone post pics of how the seat back spring is fastened to the belt rail either in front or rear of the 23-25 Tourings?
Last Name: Gregush
Post by Mark Gregush » Sat Mar 23, 2019 10:40 am
