Unidentified object found on drain plug...
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Thu Oct 21, 2021 7:03 pm
Did an oil change on the '26 Touring this afternoon and found this unidentified but obviously ferrous object sticking up from the magnetic plug.
Both sides look partially peened. One end and one side appear square and smooth, other end and side have been broken away from something bigger. Thickness about 0.050".
Thoughts? (Hopefully no prayers needed!)
Dropacent
Last Name: Morsher
Re: Unidentified object found on drain plug...
Post by Dropacent » Thu Oct 21, 2021 7:12 pm
Ring gear tooth? Ouch!
Last Name: Strange
Post by CudaMan » Thu Oct 21, 2021 7:14 pm
Kind of looks to me like the remains of a brake drum lug shoe:
https://www.modeltford.com/item/3312S.aspx
Post by Mark Gregush » Thu Oct 21, 2021 8:03 pm
If the transmission was rebuilt and new shoes added a while ago, there were some bad ones made. The grain of the steel went the wrong way or wrong temper steel was used, and they were prone to breaking along the fold lines.
Post by Scott_Conger » Thu Oct 21, 2021 8:26 pm
Marks are on the mark
and there's more where that came from :(
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Oct 21, 2021 8:27 pm
Good catch. fix quickly or OMG!
Post by Scott_Conger » Thu Oct 21, 2021 8:49 pm
Hank's right
they all need to go, and the remainder of this one needs to be found. Not a horrendous job, but a significant one for sure.
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Thu Oct 21, 2021 9:08 pm
Well, %#£¥@&#*&@X$@&!!!
Thanks guys. Bad to hear, good to know.
Post by Norman Kling » Thu Oct 21, 2021 9:39 pm
How would those get outside the brake drum? Isn't it enclosed on the front and the back?
Post by Mark Gregush » Thu Oct 21, 2021 10:52 pm
There are holes in the drive plate.
Post by Wayne Sheldon » Fri Oct 22, 2021 1:02 am
One looks at the brake drum, the steel lugs. Considers the clutch plates surrounding the steel lug. The brake drum again, the driven plate bolted tightly behind it. One thinks that no way those lug pieces could get out!
But they do. I don't know how? But I have spoken with several people that have found the pieces like this. Loose within the engine's oil. And I have read several threads just like this one.
As if that isn't enough? I myself once pulled such a lug piece out of an engine I took apart to rebuild. It was outside the confines of the brake drum and clutch.
So there.
One of the universal mysteries.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Oct 22, 2021 7:34 am
Seeing this can be a real gut ache! Been there done that!
To prevent the abnormal wear you see..., do not cruise perfectly on flat ground. Alternate your speed at times will keep this back slip/lash from happening (oscillation of power). Load up and unload power band keeps gears and lugs tight.
Hank
Post by speedytinc » Fri Oct 22, 2021 8:40 am
Them little cutting tools can work their way between the drum & band lining, not to mention your field coil. Been there.
Bit by another batch of bad repop parts.
Post by TXGOAT2 » Fri Oct 22, 2021 10:13 am
In cases where the lug shoes have begun to fail, does the car show symptoms, like clutch grabbing/dragging, making strange noises?
Post by speedytinc » Fri Oct 22, 2021 11:29 am
Mine had some sticky clutch symptoms. Came & went, came back. Inconsistent.
Post by TXGOAT2 » Fri Oct 22, 2021 11:32 am
My clutch seems to work perfectly, so I expect that the shoes are in good shape. It's smooth and consistent, and holds well.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Fri Oct 22, 2021 10:17 pm
I don't recall reading his transmission was rebuilt using our brake drum clutch shoes which are made to the original Ford print including material and heat treat. We have literally sold thousands of these shoes and have yet to receive a complaint of this nature from a customer.
Furthermore, it is not uncommon for the original shoes to fail over time due to excessive wear caused by the clutch disks. Case in point, the photo of the intact shoe shown next to the fragment.
Lastly, please try to refrain from making assumptions on the forum when you do not have all the facts. I had a conversation with the person who made the initial post and he was unable to verify if the shoes were ever replaced. I do agree he should be concerned and I also suggested he pull the engine for further inspection.
Post by speedytinc » Sat Oct 23, 2021 1:04 pm
I am not claiming these defective shoes came from you guys. This shoe problem was "common knowledge" 40 years ago & by their nature still turn up today. You might ask Glen about this, I'm sure he will remember the situation. This is another situation of bad ropop parts coming back to haunt us. My particular engine was built in the 70's. I assume the shoes were replaced @ that time. By the fact that they all split & coming apart around the same time showing little wear they had to be defective. I have disassembled a lot of transmissions that had lots of wear & dont see cracks in the bends of these shoes, much less missing pieces.
I have had very very few issues with your parts. Can only recall 1 at the moment. I am a direct kind of guy. If there is an issue, for the sake of the hobby, & your efforts to produce the best available parts I let Dave know directly.
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sat Oct 23, 2021 1:20 pm
I talked to dad and he did say there was another source many years ago (won't mention who) that did have issues. I stand corrected.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Sat Oct 23, 2021 1:40 pm
I've had one of those break in my coupe and it destroyed my magneto field coil. I'll only use original Ford wear shoes now.
Stephen
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Sat Oct 23, 2021 6:11 pm
I went thru the invoices from when this transmission was worked on in 2012… bushings, washers, pins, bands etc. but no drum lug shoes. Safe to assume I reused what was in there at the time, most likely since day one.
In hindsight, there were smarter ways to save $15. I was probably lucky to get nine good years and many thousands of miles out of them.
The Touring is up on dollies and patiently waiting the return of my loaned-out hoist and engine stand…
