Sheared Pinion Key - Can I Reuse Drive Shaft?
Randolph
First Name: Randolph
Last Name: Nowell
Post by Randolph » Sat Oct 23, 2021 5:29 pm
I thought the rear differential had come apart. Started disassembly to diagnose and found the pinion key had sheared. My question to those with more experience is this: can I clean up and reuse the drive shaft and replace the pinion key only or do I need a new drive shaft. Photos attached.
Randolph Nowell
Re: Sheared Pinion Key - Can I Reuse Drive Shaft?
Post by TXGOAT2 » Sat Oct 23, 2021 5:35 pm
Both the taper and the keyway look bad to me. I wouldn't risk it. That's a critical fit, and a failure at that point will disable the car and could leave you brake-less.
Post by Scott_Conger » Sat Oct 23, 2021 5:39 pm
Pat is right...absolutely not
Any real safety factor in a T is all but non-existent and adding potential failure modes is not something I would consider doing.
Randolph
Last Name: Nowell
Post by Randolph » Sat Oct 23, 2021 5:44 pm
Thanks both. Yeah, that's what I was thinking too. When it first failed I had no brakes... vs. normal with bad brakes. :)
Randolph Nowell
Post by TXGOAT2 » Sat Oct 23, 2021 5:47 pm
Another consideration would be alignment of the new pinion if you tried to re-use that shaft. If it didn't come loose almost immediately, it would probably have enough run-out to destroy itself in short order. I'd think it would be difficult to impossible to set up the gear clearance correctly with a new pinion on that damaged shaft.
Post by TXGOAT2 » Sat Oct 23, 2021 5:49 pm
Model Ts boil to maximize fuel economy and minimal braking helps improve tire mileage. Ford generously includes these features at no extra cost. :mrgreen:
Post by speedytinc » Sun Oct 24, 2021 11:10 am
In this case, the taper is too far gone for my taste.
I have saved cherry original shafts that had a sloppy key way by recutting the slot 180 degrees out.
They gotta be near perfect for the effort. This one goes to the cut for warford or iron pile.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sun Oct 24, 2021 11:49 am
That driveshaft has had it, I would suspect the pinion gear is also. The fit of the taper is as or more important than the key to keep it from spinning and shearing the key again. The gear should lock down on the shaft even without a key in place and not rock....
Post by Jerry VanOoteghem » Sun Oct 24, 2021 2:44 pm
With all due respect, in my estimation, that is not a good idea.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sun Oct 24, 2021 3:00 pm
Only seen the key sheer if the pinion and gear at tapes
Are not good
My suggestion fund another drive shaft or pinion and check the fit with out a key
Post by speedytinc » Sun Oct 24, 2021 3:04 pm
This is true. One thing I do is lap every gear/shaft so they hold on their own as a taper should.
Some need more than others to fit together properly. Same with axle shafts & hubs.
