Generator cutout
Rod Petrie
First Name: Rod
Last Name: Petrie
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
Generator cutout
Post by Rod Petrie » Sun Oct 24, 2021 10:56 am
Does anyone repair cutouts?
Last Name: Juhl
Re: Generator cutout
Post by Oldav8tor » Sun Oct 24, 2021 11:33 am
I think the one on the left is a John Regan voltage regulator. You might contact him (he's on this forum) and ask. I don't know about the other.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Oct 24, 2021 2:23 pm
The one on the left can be normally repaired by cleaning the points,and adjust so that the points close at about 6.5 to 7 volts. I clean and check mine once a year.
It is simpler to use a diode, but they can fail and burn up the generator armature like what happened to me when I tried a diode
Art Mirtes
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Oct 24, 2021 3:02 pm
Here is a cutout with diode inside. Note that a diode is not a voltage regulator.
Ron Patterson
Post by Ron Patterson » Sun Oct 24, 2021 5:47 pm
Art
The correct operate voltage for the reverse current cutout is 7.2 volts which is the charging voltge for a 6 Volt battey.
Ron Patterson
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Oct 24, 2021 7:29 pm
Ron,
Thanks or the info. Four years ago I guessed at the voltage. I used 4 d cell batteries at the time and it worked. I now have a very good laboratory grade dc power supply.
Art Mirtes 3
