Adjustable Valve Lifters
Dennis_Brown
Topic author - Posts: 269
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
I called Lang's and was told the 3 wrench valve lifters are no longer available. From what I have seen in the past the self locking do not always stay locked.
It appears the adjusting bolt is 1/4 inch fine thread grade 8 that has the head ground shorter. Has anyone on the forum cut off the solid lifters, ground them to the length they wanted, ground the sides parallel for a 7/16th's wrench, drilled and tapped them and made their own. Someone had to experiment originally to make them. I think it is worth a try to experiment a little. Once you cut off the end the core should be drillable.
- First Name: Henry
- Last Name: Lee
Re: Adjustable Valve Lifters
Those are going to be real hard. Those are forged steel!
Hank
Hank
Actually I had an overhead motor with 292 lifters(.500" dia) I converted those lifters as you described. To use with a flathead. No issues. Center of lifters are soft. Surface hardened.Dennis_Brown wrote: ↑Tue Oct 26, 2021 5:59 pmI called Lang's and was told the 3 wrench valve lifters are no longer available. From what I have seen in the past the self locking do not always stay locked.
I prefer the non self lockers. Never had one get loose. Did shear a self locker bolt once.
Both types of lifters are being made by colony. Sold thru colony vendors.(harley parts guys) Normally not available easily in standard size. A quick look on ebay has both types in 3 sizes. Standard non locks individually $8.75 each. 10 available now!! I prefer colony - nice thin heads for stipe cams. Get on it fast. availability swings. Revised : self lockers .030 + only.
Couldn't you just add a locking nut to the self locking style? You might need to shorten them a bit to make room for the nut, but that seems as if it would be doable?
I suppose one could. The nut might have to be made. It has to be 3/8 hex to work.Jerry VanOoteghem wrote: ↑Tue Oct 26, 2021 7:07 pmCouldn't you just add a locking nut to the self locking style? You might need to shorten them a bit to make room for the nut, but that seems as if it would be doable?
greenacres36
- First Name: Brian
- Last Name: Williams
I suppose it’s like anything else you buy from various vendors where the quality is all over the place. I bought some earlier this year from a vendor and the adjustment bolts were so tight I thought I was going to twist them off. But they didn’t. So I was delighted with them. I’ve worked on a few old Ford tractors that were converted to adjustable lifters and never had the inconsistency in the lifters that it seems that we’re having with model T parts. I too wish there was a better solution. One of my cars was already equipped with the double lock lifters and two of them had came loose. I now know why I had an intermittent miss that was driving me nuts.
Lets not forget the last recent lifter debacle. Heads were made to thick on a batch. Resized AFTER heat treat & mixed with good ones. So you end up with ONE headless lifter in a 3 cylinder T needing a tear down. How many of these time bombs remain? If that aint malicious greed?greenacres36 wrote: ↑Wed Oct 27, 2021 8:53 amI suppose it’s like anything else you buy from various vendors where the quality is all over the place. I bought some earlier this year from a vendor and the adjustment bolts were so tight I thought I was going to twist them off. But they didn’t. So I was delighted with them. I’ve worked on a few old Ford tractors that were converted to adjustable lifters and never had the inconsistency in the lifters that it seems that we’re having with model T parts. I too wish there was a better solution. One of my cars was already equipped with the double lock lifters and two of them had came loose. I now know why I had an intermittent miss that was driving me nuts.
Emeraude
- Last Name: Loranger
- * REQUIRED* Type and Year of Model Ts owned: 1921 touring
Are the 2 wrench lifters still available. ?
Got a link to one of those offerings???speedytinc wrote: ↑Wed Oct 27, 2021 11:45 amebay has all colony brand sizes & types. Couldnt tell you about normal T parts vendors
I search model t lifters in ebay. 69 possible come up. Most not material. Here is an item #. 172859881656 Seller is hdhummer.
- First Name: Henry
- Last Name: Lee
I have 4 each oversize 3 piece design used in good condition if that will help someone.
Hank
Hank
That was what I did to one of my Ts about 25 years ago. If I could still afford to buy new lifters? It is what I would do again.
And, for the record, I have made my own adjustable lifters out of old used original era non-adjustable lifters. The only reason I bothered, was at the time I was too broke to buy new lifters. All my old ones and old valves were too short to work by fitting and grinding, a method I generally prefer anyway.
Original lifters may in fact be "case hardened"? A factor I was counting on at the time. However, more than half of them were still too hard inside to drill and thread. It turned out to be a lot more trouble than it was worth. The engine they are in has never been run, but I am still hoping to find out some day whether it works at all or not?
Awesome! Thanks!!speedytinc wrote: ↑Wed Oct 27, 2021 3:58 pmI search model t lifters in ebay. 69 possible come up. Most not material. Here is an item #. 172859881656 Seller is hdhummer.
https://www.ebay.com/itm/172859881656?h ... Sw9YNZtW1d
