Model t engine block weight.
Runabout
Last Name: McClelland
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
Post by Runabout » Mon Nov 01, 2021 8:37 pm
Anyone know what a bare model T engine block weighs ?
First Name: Henry
Last Name: Lee
Re: Model t engine block weight.
Post by Henry K. Lee » Mon Nov 01, 2021 8:39 pm
Around 110 lbs!
Runabout
Post by Runabout » Mon Nov 01, 2021 8:46 pm
Thank you Mr. Lee. Greatly appreciate.
Post by speedytinc » Tue Nov 02, 2021 8:55 am
I must be stronger than I thought! Sounds like a lot.
Post by TXGOAT2 » Tue Nov 02, 2021 10:23 am
It's a heck of a lot if you drop it on your foot.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Tue Nov 02, 2021 10:58 am
it will take some time to heal your foot but the block could be ruined :)
andre
belgium
Last Name: Wrenn
Post by TWrenn » Tue Nov 02, 2021 6:05 pm
As I recall when I scrapped one a few years back it came in around 80 pounds
Post by Wayne Sheldon » Tue Nov 02, 2021 6:15 pm
Ruining a good block would be a terrible thing to do. However, your foot might grow back just fine!
About a year ago, I limped for about two weeks when I dropped something heavy and stuck my foot between it and the concrete floor! It wasn't an engine block, can't remember now what it was? But I did save it from being broken! (The model T part, not sure about my foot?)
I do find it hard to believe a bare block would weigh more than a hundred pounds? This past summer I did a much needed cleanup of my better storage shed (my mini-barn!). I had to several times move four good bare blocks and one almost complete long-block (most of the motor less head, pan, and transmission). I still lift the bare blocks fairly easily. Although, the long block wasn't as easy as it used to be.
