Help with steam engine id?
Angmar
Topic author - Posts: 341
- Last Name: Bailey
Wondering if any of you have good infromation on this engine and or where I can go to get more information on it.
thanks in advance.
Meant to put this in the off topic, not sure how to move it now.
thanks in advance.
- Attachments
- Steam 1.jpg (105.96 KiB) Viewed 3720 times
Still crankin old iron
kevinf
- Last Name: Fielding
Re: Help with steam engine id?
Try Smokestack, and list it in the steam forum. You might get lucky, just be aware there were a lot of jobbers building engines, some with very limited production. Good luck, Kevin
kevinf
Sorry you will need to go to www.oldengine.com, and then go to the smokestack forum.
Closest I could find. for "Vertical Steam Engine". There are many similar in shape but none with the same dual fly wheels. These were used in small locomotives, boats etc
RichardG
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
most likely what you have is a Kerwood, made for sears and many other outlets, the only way to find for sure is the casting numbers IF there are any,, i have owned several over the years, i have a picture taken of me 50 years ago at a show with one i saved, it ran a sausage grinder in a butcher shop,in the day not every one had electric wiring and motors to do the work but they had boilers, i will find the photo to show, that type engine was refered to as a bottle engine, depending on boiler pressure 4-6 hp,
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
I have one that is similar in construction that is marked Climax.
Angmar
- Last Name: Bailey
a few more photos. Thanks for the help guys.
- Attachments
- Steam 4.jpg (50.4 KiB) Viewed 3257 times
- steam 3.jpg (72.83 KiB) Viewed 3257 times
- steam 2.jpg (68.75 KiB) Viewed 3257 times
it would help to know what this says...
??canton Pump C0. A20?? Canton Ohio
- Attachments
- pump 4.png (364.89 KiB) Viewed 3231 times
kevinf
That last photo is of a duplex pump
Steam cylinders on one side and the pump cylinders on the other. Used as a boiler feed pump.
