Location of Grease Fittings on Ruckstell Shifter Housing…
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri Nov 05, 2021 9:16 pm
Does anyone have a picture copy of the location where Stan Howe used to install the fittings? Thank you…..
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: Location of Grease Fittings on Ruckstell Shifter Housing…
Post by MichaelPawelek » Fri Nov 05, 2021 9:33 pm
Finally did find this picture but I think I remember a later version with 2 fittings?
Post by Scott_Conger » Fri Nov 05, 2021 9:37 pm
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Nov 05, 2021 9:39 pm
It will not do much good except pump grease into the axle in the first pic. Look closely at stans pic, two fitting right there will do the trick. You can use little button fittings that you drive in a hole, very inconspicuous that way, and it delivers grease right where you want it.
Post by Original Smith » Mon Nov 08, 2021 11:11 am
I've been running Ruckstell's in all my cars for 60 years, and see no need for additional lubrication. However, mine are the earlier version.
Dropacent
Last Name: Morsher
Post by Dropacent » Mon Nov 08, 2021 12:14 pm
Aye, there’s the rub, Larry HOWEVER! …………. Of course the early style doesn’t need extra lubrication. Stan had it correct.
