Quick Question on Hydraulic Disk Brakes
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Mon Nov 08, 2021 12:51 pm
I thought I was done with my disk brake project on my 26 Touring but have a lingering question.
The hose from the remote reservoir is a bit long and I let the hose droop a little below the level of the master cylinder in the routing. Seems to make no difference and the system bled ok. Do you think this will create a problem?
Thanks,
Mike
Re: Quick Question on Hydraulic Disk Brakes
Post by TXGOAT2 » Mon Nov 08, 2021 1:53 pm
I don't believe that would be a problem if you were able to get the system fully bled. Ideally, every line in a system would be placed so that bubbles would rise to the highest point in the system. I doubt that's ever been accomplished.
Model T Ron
First Name: Ronald
Last Name: Bakow
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Post by Model T Ron » Mon Nov 08, 2021 1:58 pm
You will be fine as long as the air is out.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 08, 2021 11:03 pm
Hi Michael,
Gravity being the weakest but most persistant force in the universe it shoud not be a issue unless it kinks over time. Check it once in awhile, you never know when the extra hose will come in handy.
