Tire pump hose fitting - Found
Gator
First Name: William
Last Name: Gates
Post by Gator » Tue Nov 09, 2021 8:50 am
I have this pump that I just installed a rebuild kit in. I am missing the fitting on the base to connect the hose to. Does anyone know where to get one?
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Re: Tire pump hose fitting
Post by R.V.Anderson » Tue Nov 09, 2021 10:17 am
What year is your pump, or what year car is your pump going with? There were several different styles. I have the drawings for all of them; they are simple enough that you could make your own.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Tue Nov 09, 2021 10:19 am
:oops: I apologize; I misread your post. I thought you were looking for the clamp that secures the hose to the fitting. Stupid. :oops:
Dropacent
Last Name: Morsher
Post by Dropacent » Tue Nov 09, 2021 12:47 pm
I believe I have a loose original with the check valve. Tmorsher@icloud.com and I’ll look
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 09, 2021 1:04 pm
I should have some too just need to know what thread size you require.
Hank
Gator
First Name: William
Last Name: Gates
Post by Gator » Tue Nov 09, 2021 3:15 pm
I got this pump to go with my '26 touring. Probably not correct with the brass body but I like it. I tried to determine the size. First glance just figured 1/8" pipe, but way smaller than that. 1/4" fine slips in, 5/16" too big. Got it in my mind that it might be the same size as a valve stem. Acts like wants to start in but doesn't. Threads may be dinged but I didn't want to go too far until I knew for sure.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Nov 09, 2021 5:48 pm
Will take a look tomorrow.
Hank
Post by Steve Jelf » Tue Nov 09, 2021 11:21 pm
I have the same pump, or maybe an excellent reproduction, and it has no check valve. The chuck should have no center post, so the tube stem serves as a check valve.
First Name: Henry
Last Name: Lee
Re: Tire pump hose fitting - Found
Post by Henry K. Lee » Wed Nov 10, 2021 10:09 am
Gator,
I found a few in my odd box, closest one is a 5/16” x 24 NFT with a check valve. I do have one only of the odd 9/32” x 32 NFT with no check valve. $12.00 each plus shipping.
Let me know,
Hank
