Support Forum
Brent Mize
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post
by Brent Mize » Fri Dec 03, 2021 5:45 pm
Hi guys,
My painter misplaced my body bolts for my 27 touring.
I’ve searched in vain and cannot determine what size they were.
I’ve used Bruce McCalley’s hardware list and but I still can’t seem to locate the size, thread pitch and nut size.
I been through all of the catalogs too. No luck. Perhaps I’m missing something somewhere.
Any help would be appreciated.
Thanks in advance,
Brent
Pep C Strebeck
- First Name: Joseph
- Last Name: M
Post
by Pep C Strebeck » Fri Dec 03, 2021 7:04 pm
They are 7/16-20, and I believe they are 3 different lengths, front 25/32" center 1" and rear 1-9/16". And if I remember correctly the nut is 11/16" and the bolt head is 9/16".
Post
by Mark Gregush » Fri Dec 03, 2021 10:04 pm
Brent Mize
- First Name: Brent
- Last Name: Mize
Post
by Brent Mize » Sat Dec 04, 2021 4:45 pm
Thanks for your help!
Brent
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Post
by R.V.Anderson » Sat Dec 04, 2021 8:23 pm
Brent, are you looking for the body MOUNTING bolts? If so, and you can wait just a bit, these have finally come up to the top on my fasteners project list, now that the rear axle housing bolts/nuts are finished. I have sent the factory drawings to my "small run" automatic screw machine shop (owned by a cousin) and am awaiting their quote on full sets of these bolts. They do top quality work and make many of the fasteners I supply.
Brent Mize
- First Name: Brent
- Last Name: Mize
Post
by Brent Mize » Sun Dec 05, 2021 12:40 pm
Rv,
Yes, the body mounting bolts for the 27 touring. I’m looking at Spring 2022, so if you could have them by that time, I’d like a set.
Just let me know.
Thanks so much!
Brent!
R.V.Anderson
- First Name: R.V.
Post
by R.V.Anderson » Sun Dec 05, 2021 6:45 pm
Brent, they should be ready by the middle of January.
Post
by TRDxB2 » Sun Dec 05, 2021 8:13 pm
Pep C Strebeck wrote: ↑Fri Dec 03, 2021 7:04 pm
Right on
Brent Mize
- First Name: Brent
- Last Name: Mize
Post
by Brent Mize » Mon Dec 06, 2021 1:23 pm
Thank you all for your help!
Brent
J1MGOLDEN
- Last Name: Golden
Post
by J1MGOLDEN » Mon Dec 06, 2021 2:13 pm
R V, a friend of mine exhausted all sources look for a set of body bolts for a 1916 Touring.
He will buy a set if you get some of those!
Keep me posted.
