Should There be a Cutter Key Here?
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Mon Dec 06, 2021 8:41 pm
Photos of my 1927 coupe front axle are attached. Should there be a cutter key on this nut?
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Re: Should There be a Cutter Key Here?
Post by Bill Robinson » Mon Dec 06, 2021 8:44 pm
4 sure! a widow maker if there's not one!
Post by Norman Kling » Mon Dec 06, 2021 8:48 pm
Yes !!!!!!
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Mon Dec 06, 2021 8:59 pm
Cotter Pin.
Post by Scott_Conger » Mon Dec 06, 2021 9:07 pm
Not only a cotter pin, but be sure the nut is the proper special nut with a convex bottom to mate to the concave surface of the wishbone.
Post by Mark Gregush » Mon Dec 06, 2021 10:38 pm
Hope those nuts are loose also the perches, so you can line them up when spring is installed? That one perch looks 90 degrees out of alignment.
Post by Allan » Tue Dec 07, 2021 1:28 am
I have not seen a nut like that one! Whatever nut is used, it does need a split pin.
Post by John kuehn » Tue Dec 07, 2021 9:10 am
Yes it needs a cotter pin! You may need to use a pick to dig out the paint to find the hole for the pin to go in.
Post by Steve Jelf » Tue Dec 07, 2021 11:36 am
You can leave the cotter pin out if you want to have a wreck. :)
Post by TRDxB2 » Tue Dec 07, 2021 11:56 am
That's the one with the cotter pin issue. BUT are the perches on the correct ends - boss to the back.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Dec 07, 2021 12:18 pm
http://www.mtfca.com/discus/messages/70 ... 1513701371
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Wed Dec 08, 2021 7:43 pm
I was almost sure a cotter pin was needed, but thought I would ask. I am glad I did because of all the good cotter pin information that was posted. Thanks to you all.
Post by TRDxB2 » Wed Dec 08, 2021 8:56 pm
Castellated nuts are designed to use cotter pins & not lock washers. However, not every nut on a Model T is a castellated one. So make sure the nuts are good before you try and insert your pin. :oops:
List of hardware.pdf
(862.79 KiB) Downloaded 94 times
Post by speedytinc » Thu Dec 09, 2021 3:46 pm
Thanks for posting this cotter pin use chart.
I find even this "trivia" level of info very interesting & helpful to my T knowledge base.
Thats appreciation to any & all posting this sort of enlightening information.
