Multi lift Junior
Khill0105
Topic author - Posts: 40
- First Name: Kyle
- Last Name: Hill
- * REQUIRED* Type and Year of Model Ts owned: 1925 depot hack. 1924 4door 1920s racer 1923 TT
Multi lift Junior
Looking for pictures of the multi lift junior. I’ve searched the forum and have read several posts on the subject but no pictures. If anyone has a set or pictures could you please post them. If you have a set could you please post a picture with a ruler in the picture also.
Thanks everyone Kyle
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Mike Penserini
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Re: Multi lift Junior
The late Jerry Hunt reproduced Multi Lifts a while back and sets pop up from time to time. When Riley was originally making his Multi Lifts he was also producing a head to be used with them.
Khill0105
- First Name: Kyle
- Last Name: Hill
Thanks so much guys for the pictures and the links. I think I’m definitely going to have to try to make a set
I installed a NOS set in my 14. Used a reground cam with .230 lift with model A cam durations. (seemed like the perfect cam), New stainless valves & stock springs. VERY DISAPPOINTING RESULTS.
At first it ran well. not a world beater, but well.
with in a year, it started running on 3 & back popping thru the carb. determined #4 exhaust was barely opening.
When i opened the valve covers for a look, i couldnt believe the mess.
One upper pivot pin was shattererd, 2 were in place broke, 4 of the valve stems had a 3/4"radius worn away a good 1/4"+ up the stem where upper lift arms contacted.
EVERYTHING WENT WRONG.
Any body running these things successfully?
What could i have done so wrong?
DustySpokes
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
A question that is related to the double spark head. I finally got one after a looong quest. What spark plugs are best suited for these heads ? As to the lifters, I wonder if it is a challenge to get the bases locked down good and tight so that they do not move ?
Les Schubert
- First Name: Les
- Last Name: Schubert
I have a set of new reproduction multi lifts. I am thinking about installing them just on the intake valves. I know some people that have run them quite successfully
- First Name: Henry
- Last Name: Lee
Heres a set for $410.00 with shipping.
Craig Leach
- First Name: craig
- Last Name: leach
The device for holding the multilifts in place and lubrication seems to be the big issue. The very colorfull pictures show a beefed up version as for this picture. Running a line from the hogshead or drip oilers may solve the lubrication issue
Craig.
Craig.
Craig Leach
- First Name: craig
- Last Name: leach
I have also heard mention of a device to hold the framework centered in place over the tappet bosses.
Craig
Craig
