Fun Projects Technical Library
QGolden
Topic author - Posts: 88
- First Name: Quinn
- Last Name: Golden
Hello
Does anyone know if the Fun Projects Technical Library was ever reposted anywhere?
Specifically looking for “Model T Ignition Coil” parts 1-3.
Thank you.
Thank you.
dykker5502
- First Name: Michael
- Last Name: Deichmann
Re: Fun Projects Technical Library
I saved them in time:
Ford Model T 1914 Touring
QGolden
- First Name: Quinn
- Last Name: Golden
Awesome! Thank you so much! I started building Model A Speedsters a long time ago, and tended to bookmark rather than download documents. Going back now, so many of those valuable sites are gone. I too save everything I come across now.
Chris Barker
- First Name: Chris
- Last Name: Barker
Well done Michael!
Maybe this Forum should have a library of worthy documents.
Just consider how much time and effort might be saved if we could just send people to read those three!
jab35
- Last Name: Bartsch
Chris is absolutely right, the FunProjects (RIP) technical information is right up there with Vowell Art in terms of accuracy, relevance, and value to the Model T community, and should be archived in the MTFCA website. jb
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
This link will take you to the last image of the website in 2016. Unfortunately none of the documents appear to be there
https://web.archive.org/web/20161012003 ... hinfo.aspx
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
http://www.funprojects.com/pdf/HCCTManual.pdf
http://www.funprojects.com/pdf/WheelpressA2.pdf
https://web.archive.org/web/*/http://ww ... s.com/pdf/*
On the last link, click the item you want to see, then click the date highlighted on the calendar. It should pull it up for you. If you click the one for speedometer, you get a firewall that shows the typical speedo mounting area
- Last Name: Hjortnaes
William
I get Internet Archive Wayback Machine website and it displays a 2010 calendar.
Will_Vanderburg
I don't think it matters what year the calendar shows just as long as you click on one of the highlighted dates. On the list link I provided (Third link), it tells you how many times that particular article was captured and the calendar range dates.
For example, the HCCT pdf. That was captured two times from March 2006 to March 2016
Ron Patterson
Looks like "Wayback Machine" requires some payment to see the items to support the cost of their site?
Ron Patterson
Ron Patterson
Will_Vanderburg
I have no idea where you came up with that. I look at it all the time and don’t pay a dime.Ron Patterson wrote: ↑Fri Dec 31, 2021 6:33 pmLooks like "Wayback Machine" requires some payment to see the items to support the cost of their site?
Ron Patterson
Joe Voller
- First Name: Joe
- Last Name: Voller
- * REQUIRED* Type and Year of Model Ts owned: 1924 pickup 1922 centerdoor
it doesnt work for me ,i only get 1 date that lights up in2010 and get error on that date
