Cleaning Metal Spokes….
MichaelPawelek
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
As I get older cleaning metal spoked wheels gets a bit harder especially on the back side. The cone shaped brushes do ok but I wonder if anyone has found a better option. Maybe a soft fluffy mitt style on a short handle? What have you found the best and easiest to use?
- First Name: Dennis
- Last Name: Seth
Re: Cleaning Metal Spokes….
The best thing to use is a ten dollar bill and the kid next door!
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
It certainly is a chore to do a good job. I jack up each wheel so I can turn it to be sure I don't miss a spot front and back using an old wash cloth. If I'm real ambitious I take the wheels off.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
MichaelPawelek
John, My 800 foot driveway to the front gate is paved and the main road in the subdivision is paved also. My problem is the 100 yard stretch in between made from crushed concrete that our County uses that is mostly dust when dry. My spoked wheels get filthy just driving in and out 3-4 times and I can’t imagine jacking up the wheels 2-3 times per week during driving season!
JohnM
You could creep slow to not kick up much dust and hope no car flies past you,
or lobby to have it paved.
MichaelPawelek
I could try driving in Ruckstell/Ford Low and will give it a try. As far as lobbying to have the 100 yards paved by the County I am out of luck. I live in one of the fastest growing Counties in the United States and they are building so many new roads they are ignoring those already built.
JohnM
I have moved to a rural location where it is two miles of gravel to the pavement. I LOVE IT. But, it is harder to keep cars clean. If I go slow and no cars pass going the other way, they stay pretty clean.
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
I put the cars on jack stands and use the power washer to clean the wheels and tires. Running in gear works great.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
