Broken Magneto Horn Bolt
PaladinBirdy
First Name: Josh
Last Name: Hollingsworth
* REQUIRED* Type and Year of Model Ts owned: 1919 Touring Pickup
Post by PaladinBirdy » Wed Jan 12, 2022 12:01 pm
Tried to adjust my magneto horn, barely put any pressure on the stuck nut and the brass bolt snapped right in half. The lower half of the bolt is still in there. How difficult is this gonna be to fix? Is there an easy way to replace the bolt or should I get to soldering?
A 'youngin.
Re: Broken Magneto Horn Bolt
Post by DanTreace » Wed Jan 12, 2022 12:18 pm
Haven't repaired a magneto horn before, but others have.
Took this photo off the web, and it shows the mag horn with its pieces apart.
That brass bolt perhaps is part of the piece that drives the diaphragm. Maybe the photo helps.
Mag horn apart.jpg (46.09 KiB) Viewed 2556 times
Post by Rich Eagle » Wed Jan 12, 2022 1:23 pm
This is what the my mag horn nut looks like. It crimps into the diaphragm. I don't have the screw and 1/4-28 won't go all the way through. It might be extra fine.
jab35
Last Name: Bartsch
Post by jab35 » Wed Jan 12, 2022 1:46 pm
Maybe it's 14-24 bolt. Try a bendix cover screw or old brass magnet clamp screw if you happen to have one lying round.
Post by Rich Eagle » Wed Jan 12, 2022 3:50 pm
I found the screw. 1/4-32. I was in error when I measured the thread. The OD was .240 and I mistook it for #12 and got the thread count wrong. I'm confident it is 1/4-32. I will inform Martynn Vowell.
PaladinBirdy
First Name: Josh
Post by PaladinBirdy » Thu Mar 03, 2022 10:26 am
Yikes. Where am I gonna find a 1/4-32 bolt/screw?
A 'youngin.
jab35
Last Name: Bartsch
Post by jab35 » Thu Mar 03, 2022 11:40 am
John Regan may know, he's still serving the model community as JRC Products, LLC. piewagon(at)gmail(dot)com jb
The Vowell Art mag horn diagram shows 1/4-32 x 1 1/4 " long center bolt. app.php/gallery/image/2257
Post by Rich Eagle » Thu Mar 03, 2022 12:05 pm
McMaster-Carr
https://www.mcmaster.com/screws/thread-size~1-4-32/
They may have a minumum order.
JimmyT831
Last Name: Long
Post by JimmyT831 » Sat Mar 12, 2022 6:57 pm
PaladinBirdy,
Finally checked my messages.
Sent you a reply. I still have what you need.
Jim
