1925 Ford Timer Assembly
Wascator
First Name: Randy
Last Name: Roberson
* REQUIRED* Type and Year of Model Ts owned: 1925 Fordor, 1926 Coupe
Post by Wascator » Thu Jan 13, 2022 8:49 pm
I bought a reproduction Ford timer, new roller, roller pin, brass shield, and felt. The brass shield and felt were missing from my car, so I am unsure about how they go. I pushed the felt seal snugly in place (I think) but what holds the brass shield? Is tgere a washer between it and the roller!
Last Name: Humble
Board Member Since: 2006
Re: 1925 Ford Timer Assembly
Post by Humblej » Thu Jan 13, 2022 9:14 pm
If I remember correctly, the timer holds the shield in place, so when the timer is off the shield will be loose.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Jan 13, 2022 9:14 pm
On roller timers that require lubing a tiny bit every 200 miles or so I have never found it necessary to use the felt or brass shield.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Thu Jan 13, 2022 10:17 pm
The last few engines I put together I did with the modern cam seal and didn’t use the felt or shield. All is good. Clean the timer housing when I think about it and go on with life.
Brad
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Thu Jan 13, 2022 10:28 pm
If you use the brass shield make sure it is big enough to span the timer case. Some repro shields are too small and are not held in place by the timer adequately.
