Model T mystery Puller Tool
Sam Hotton
First Name: Sam
Last Name: Hotton
Post by Sam Hotton » Tue Jan 18, 2022 8:45 pm
Anyone know what this Puller Tool is for?
I think it's Model T, but not sure for pulling what?
It sort of looks like a Hub Puller, but the Model T ones I've seen just screw on.
It's got a number on it that starts with " T " which makes me think it's a Model T tool.
The number looks like "T266" or "T288", etc. I don't know, it's hard to make out.
The opening slot width is a loose 2-1/16" wide.
Anybody got any ideas on what it's for?
Re: Model T mystery Puller Tool
Post by Norman Kling » Tue Jan 18, 2022 8:52 pm
It might be a puller for 26-27 hubs with wire wheels?
Sam Hotton
First Name: Sam
Last Name: Hotton
Post by Sam Hotton » Tue Jan 18, 2022 8:56 pm
OK Norm, that's a possibility I hadn't thought of!
Can anyone confirm this is what it is?
Post by RajoRacer » Tue Jan 18, 2022 9:17 pm
Not like any Ford tools illustrated in any of the Ford literature I've seen.
Post by Mark Gregush » Tue Jan 18, 2022 9:57 pm
Could be Model A hub puller.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Jan 18, 2022 9:59 pm
A better design of an original with the upper web bridge but it appears to be a 1926/27 hub puller for wire wheel hubs.
Hank
Sam Hotton
First Name: Sam
Last Name: Hotton
Post by Sam Hotton » Tue Jan 18, 2022 10:11 pm
I seem to remember that Model A & 26/27 Model T with wire spokes used the same rear hub puller?
Anyone know if this is correct?
Post by Scott_Conger » Tue Jan 18, 2022 10:24 pm
The Ford puller for wire wheel hubs was a massively proportioned two-fingered affair and sported a "5-Z-1172" number
If this is a tool for a Model T, it is an aftermarket tool, and very lightly proportioned for the job.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Jan 18, 2022 10:25 pm
It looks the same as a T70 Model A Ford rear hub puller sold on tbay
https://www.ebay.com/itm/184904602595?n ... 7675.l2557
Post by Mark Gregush » Tue Jan 18, 2022 10:29 pm
Side note; There were two different Model A hub pullers, to fit the flange or groove type hub. The distance between the sides of the puller where it slides on would be different between the two styles.
Sam Hotton
First Name: Sam
Last Name: Hotton
Post by Sam Hotton » Wed Jan 19, 2022 1:00 am
My Tool is a pretty hefty & solid tool.
It weighs a decent 7.1 Lbs !
