Front Door size
Topic author - Posts: 6
- First Name: Rik
- * REQUIRED* Type and Year of Model Ts owned: 1
Front Door size
Hi,
Will '23 doors fit a '17 - '21? Sorry for the newby question...are there any size differences in the early roadster/touring front doors? I'm still picking away at the old roadster body I found in a ravine back in the '90's. Possibly a guy or two who has been around since the early 2000's remembers me?...life has gotten in the way several times since then. Back then I had assembled 90% of a chassis but I had to let it all go and shelve the project due to a move. In that time I have still never run across the tools/space to do the woodwork but was recently contacted by a guy I sold my extra body panels to saying he might have a wood guy lined up....
I found it in Washington and it has the non functional driver's door, but I am Canadian and since this car will always be a Jacob's coat I'd like to convert to a functioning driver's door. I have found a local guy selling a pair of doors for a '23 but the main body is the early "low cow" '17-'21 era...
Can I use the '23 doors on this body?
- Thanks
- Thanks
- Last Name: House
Re: Front Door size
1923 open Model T s are also of the low cowl variety and the doors will fit but I’d advise against it.
- First Name: Rik
Re: Front Door size
Is that because you feel it might damage the historical significance or value? If so trust me it won'tGeorge House wrote: ↑Fri Jan 21, 2022 1:42 pm1923 open Model T s are also of the low cowl variety and the doors will fit but I’d advise against it.
P.S. this "car" is like a stray dog... a mutt... there are no numbers (pedigree) it followed me home and I intend to put the 100 year old bits of scrap tin back together because A) of the adventure I had finding it B) I can't throw it away (even though I should)
Re: Front Door size
Doors from 1915 to sometime in 1925 are the same. If you are trying to add a left door to left-hand drive, sounds like a lot of work for not much return. Because of the layout, it's kinda worthless. Now if you have right-hand drive, left-hand body, that would be different. Touring/roadster front doors are the same for both.
- Last Name: House
Re: Front Door size
Rik, 1923 was a transition year. From the middle to end of’23 Ford produced wide cowl, 5 rib firewall Model T s that’s known as ‘24 models. Open car doors weren’t taller or shorter in the years Mark advised. As he also stated; if your T is US left steering, cutting and installing a driver side door will be almost useless for ease of ingress and egress. I have a US ‘26 roadster with a factory left side door and don’t ever use it - pain in the butt.
- First Name: Rik
Re: Front Door size
Thank you! that's great info I knew the rear of the cab was different than the '23 I had and I knew about the change in hood/cowl/grille but I wasn't sure if the doors ever changed...Mark Gregush wrote: ↑Fri Jan 21, 2022 2:16 pmDoors from 1915 to sometime in 1925 are the same. If you are trying to add a left door to left-hand drive, sounds like a lot of work for not much return. Because of the layout, it's kinda worthless. Now if you have right-hand drive, left-hand body, that would be different. Touring/roadster front doors are the same for both.
Well I fully accept the "worthless" part
It should be pretty simple... a lip around the door opening...Also as I'm sure you are aware Canadian Model T's had 2 functional front doors so not much work for a good "Canadian" return
- First Name: Rik
Re: Front Door size
Thanks George and Mark, I get what you're saying now the steering /column/wheel/ pedals are right in the wayGeorge House wrote: ↑Fri Jan 21, 2022 2:34 pmRik, 1923 was a transition year. From the middle to end of’23 Ford produced wide cowl, 5 rib firewall Model T s that’s known as ‘24 models. Open car doors weren’t taller or shorter in the years Mark advised. As he also stated; if your T is US left steering, cutting and installing a driver side door will be almost useless for ease of ingress and egress. I have a US ‘26 roadster with a factory left side door and don’t ever use it - pain in the butt.
- First Name: Rik
Re: Front Door size
But basically to sum it up: ...there are no "high" doors for pheaton / roadster ...all the doors are the same dimensions?
- Last Name: House
Re: Front Door size
Yep, ... you got it
Re: Front Door size
Add to that list, the parking brake lever.Low Bucket wrote: ↑Fri Jan 21, 2022 2:43 pmThanks George and Mark, I get what you're saying now the steering /column/wheel/ pedals are right in the wayGeorge House wrote: ↑Fri Jan 21, 2022 2:34 pmRik, 1923 was a transition year. From the middle to end of’23 Ford produced wide cowl, 5 rib firewall Model T s that’s known as ‘24 models. Open car doors weren’t taller or shorter in the years Mark advised. As he also stated; if your T is US left steering, cutting and installing a driver side door will be almost useless for ease of ingress and egress. I have a US ‘26 roadster with a factory left side door and don’t ever use it - pain in the butt.
Re: Front Door size
Having brought back a '23 runabout back from the brink of scrap, I can state with total certainty, that adding the complication of adding in a door to a driver's side panel would have added intolerable time and effort to the complication of the not-so-simple creation of the wood structure and the restoration of the sheet-metal. Canadien or not, I sure would NOT do it.
Additionally, though I own 4 "T"s", while lots of folks restore them, I would NEVER AGAIN bring a completely and totally decrepit T back to life unless it was 1913 or older. There are too many $4000 rolling/almost-running T's out there to putter on for far less effort.
Watching a Don Booth restoration via pix on the forum is a FUN proposition. What you do not see is the MAMMOTH time and effort involved in just the wood. Add to that large chunks of missing metal that is corroded to 1/2 it's original thickness and you have a whopping job without the complication of adding a door.
Reconsider.
Reconsider.
