Looking For Stop Light Switch Instructions
BE_ZERO_BE
Topic author - Posts: 662
- First Name: BOB
- Last Name: CASCISA
Does anyone have the installation instruction sheet for the Fun Projects Stop Light Switch?
Could you please post or emil me a copy?
Thanks.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Re: Looking For Stop Light Switch Instructions
I believe I do Bob - going out to the shop in a bit.
Bob
Here you go. These are instructions.
BE_ZERO_BE
- First Name: BOB
Thanks Dan & Steve.
Be_Zero_Be
Be_Zero_Be
OldFordGuyDan
- First Name: Daniel
- Last Name: Adcock
- * REQUIRED* Type and Year of Model Ts owned: Several
I use a motorcycle brake light switch on all my Ts and work very well. Easy bracket to make even I can do it!
- Last Name: Wrenn
Dan...is there any info and/or pics you could post? Seems like the venerable "fun projects switch" will be no more. I keep hearing from certain people "oh its being made" but never seems to surface. Luckily I found an un-needed couple of F.P. switches to finish my fleet so at least I'm good. But others may be interested in your design.
Would like to see what has been done too. These look they could be used very easily
BE_ZERO_BE
- First Name: BOB
Google "Starter Button Switch".
A large number of booted switches will come up.
Most under $10.
Most under $10.
Be_Zero_Be
Be_Zero_Be
