Holley H1 carburetor problem
Post by Allan » Wed Feb 02, 2022 5:21 pm
My 1912 Haighs chocolate van was getting very hard to crank start, so I had to fit a replacement H1 carb Stan Howe rebuilt form me. I was disassembling the original one to check how the float arm/needle and seat looked when I discovered the likely cause of the hard starting. The laminated cork float had shrunk somewhat, making it loose on the arm. As a result the float was able to move on the tiny bolts, up to 3/8", so i had a variable height float setting. Of course, removing the assembly resulted in a broken cork float, so now I have a job carving a new replacement.
I bought an incomplete third H1 at a swap meet, and was trying to see whether a replacement float arm I discovered in my spares stash was correct for it. It wasn't!
Last Name: Tannehill
Re: Holley H1 carburetor problem
Post by JTT3 » Wed Feb 02, 2022 8:59 pm
You can get the arm from Lang’s. You can repair the cork float by super glueing it together and then coating it with a product called Red Kote. I actually have repaired several cork floats that way on H1’s, 5 balls, Holley G & 4 balls.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Wed Feb 02, 2022 10:10 pm
If you don’t want to pay for shipping from the USA for a float arm you can make one out of brass then get a needle and seat for a Quadrajet carburetor and put it in there. You don’t have to modify it for an H1. Assuming you can get a Quadrajet needle and seat in Australia at a local parts house. Just drill and tap 3/8-24. Then you won’t have to worry about the finicky original setup.
Post by Allan » Thu Feb 03, 2022 2:16 am
John, thanks for the tip about the arms from Langs. They must have been problematical. The one in the incomplete carb was broken diecast. The one in my original is a brass casting. The float looks like the one on the left in your photo
Corey, thanks for the photo of the made up float hinge. That should not be a problem to make. I still need the stepped plug/hinge pin that screws in the side. The float you show looks much like a Holley G item. my H1 float is much lighter than that one.
Quadrajet carbs were used on some Holden engines here in Australia, so I'll have to look into a local supplier. Stan fitted a viton needle and seat to my rebuild carb. He offered the tap to fit others, but he did not indicate the vehicle/carb on which it was used.
