who solders brass for repairs?
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Post by TBones12 » Thu Feb 03, 2022 2:26 pm
I am looking for someone to solder the brass horn coil hose tot he reed.
Also if they can, to beef up the stem that attaches the horn to the body / door. I have had several of these over the years and they all snap apart.
Do they make a strong horn support ?
Than you, Bob Poane
Re: who solders brass for repairs?
Post by Rich Eagle » Thu Feb 03, 2022 3:07 pm
If you have a local music shop that repair trumpets and saxophones they could do a nice job for you.
Last Name: Wrenn
Post by TWrenn » Thu Feb 03, 2022 3:45 pm
It's not that hard to do yourself really. I've done it before with success. Trouble is with those re-pop horn bulb brackets, they're so small and flimsy at the attachment point you can repair all you want and they still will break. I copied some other guys idea and got rid of the "post" and used a brass bolt & nut and it did the job quite well. Just a though Robert.
Post by Jerry VanOoteghem » Fri Feb 04, 2022 9:12 am
The bracket needs silver solder. The tube should have a brass sleeve fit over the broken section to reinforce it, then solder.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Feb 04, 2022 2:53 pm
What Jerry said- soft solder will not hold the stem on the bracket. Soft solder on the tube should be ok. I had one that would break every time my knee bumped it. Since I silver soldered it, no more issues. Who ever makes these should take note.
TBones12
Last Name: Poane
Post by TBones12 » Fri Feb 04, 2022 5:45 pm
Thank you! c You all gave me a great idea.
Sheri
First Name: Sheri
Last Name: Cameron
* REQUIRED* Type and Year of Model Ts owned: 1909, 1911, 1915
Post by Sheri » Fri Feb 04, 2022 10:07 pm
These reproduction brackets fail frequently due to the poor joining to the base plate and because the post section is much taller than on the original part and thus is easy to put under bending stress when bumped into. I suggest you shorten the post by half before you silver solder it back to the base. You will have a much better chance of it holding up over time. This is what i do when repairing these reproduction brackets.
TBones12
Last Name: Poane
Post by TBones12 » Sat Feb 05, 2022 2:06 pm
Good idea. Thank you Sheri!
John Codman
Last Name: Codman
Post by John Codman » Sat Feb 05, 2022 4:48 pm
If you can find a skilled model railroader, they make model locomotives out o soldered brass
John Codman
Last Name: Codman
Post by John Codman » Sat Feb 05, 2022 4:49 pm
If you can find a skilled model railroader,;, they make locomotives out of soldered brass.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Feb 08, 2022 9:05 am
Hi Robbert, I will be interested seeing pictures of what you done. Look interesting way to resolve the issue as well
Super Mario Bross ;)
1911 Touring
1914 Speedster
