Flywheel dowel pins
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Flywheel dowel pins
Post by Don ellis » Sun Feb 06, 2022 5:00 pm
Is there a certain direction they press out like the triple gear pins?
Kerry
Last Name: van Ekeren
Re: Flywheel dowel pins
Post by Kerry » Sun Feb 06, 2022 5:33 pm
They only come out one way, tap them out with a drift and hammer, not that tight, from the transmission side.
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Sun Feb 06, 2022 5:39 pm
Thanks, I started that direction but thought I would ask to be safe.
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Mon Feb 07, 2022 1:39 am
And they are pressed in from the backside. The fitted area is about .001 larger than the post. Sometimes when they have been removed some material can also be removed and you may need a larger base for a tight fit.
Kerry
Post by Kerry » Mon Feb 07, 2022 2:24 am
I'm not sure on following you David, the dowels would tap in on the magnet side, to me that would be the front of the fly wheel as it faces the front of the engine.
