Needing a Junk Transmission Drum
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by dunoon » Mon Feb 07, 2022 5:35 pm
I need a trans drum to use for checking roundness of bands anything will do as long as the drum surface is OK. Tried to find one here where I live but, no luck, let me know what ya have, width doesn't matter. Thanks
Bill Serbst
First Name: Bill
Last Name: Serbst
* REQUIRED* Type and Year of Model Ts owned: 1919 speedster (in progress)
Re: Needing a Junk Transmission Drum
Post by Bill Serbst » Mon Feb 07, 2022 6:28 pm
PM has been sent.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Mon Feb 07, 2022 6:57 pm
Interesting the subject came up as I was just watching a model t tips video on transmission band relining. The guy in the video was using a axle brake drum to check roundness. Iam assuming it was a small drum axle but I don’t know the diameter. Maybe someone here knows?
Last Name: Seth
Post by perry kete » Mon Feb 07, 2022 7:37 pm
Why not just cut a disc out of plywood to the size of the drum you need to set roundness
