paint code for 1915 Canadian midnight blue
brian2264
First Name: Brian
Last Name: Healey
* REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1915 Canadian touring 1915 roadster boat tail speedster
Post by brian2264 » Tue Feb 08, 2022 6:37 pm
getting ready for paint on a 1915 Canadian touring. Does anyone know the correct paint code for the midnight blue? Thanks
Les Schubert
First Name: Les
Last Name: Schubert
Re: paint code for 1915 Canadian midnight blue
Post by Les Schubert » Tue Feb 08, 2022 8:17 pm
I can send you a picture of my 13 RHD Canadian touring. I built it almost 25 years ago and I believe it is a authentic colour. If you like it I can probably get it scanned.
Lgitts
First Name: Les
Last Name: Gitts
* REQUIRED* Type and Year of Model Ts owned: '11 Torpedo, '13 Towncar, '22 Centerdoor
Post by Lgitts » Tue Feb 08, 2022 8:31 pm
The top formula is for PPG- DBC base coat, which must be clear coated. This is for mixing a qt. The hand written values are for a pint. This is the color for 1911 through 1913 US Fords.
It's expensive. Hope this helps.
Lgitts
First Name: Les
Last Name: Gitts
Post by Lgitts » Tue Feb 08, 2022 8:33 pm
I forgot to add: DBC mixes 1 to 1 with reducer, so (1) qt of base equals (2) qts sprayable.
Last Name: Wrenn
Post by TWrenn » Wed Feb 09, 2022 11:20 am
I wonder if the PPG formula would also work with a single stage urethane...I'll take this to my paint people and see this spring.
pron022020
First Name: Tyler
Last Name: Prondzinski
Post by pron022020 » Wed Feb 09, 2022 12:19 pm
Different tints and binders with base vs single stage. It won't directly transfer over but they could probably do the work and make it in single stage.
nsbrassnut
First Name: Jeff
Last Name: Lee
Post by nsbrassnut » Wed Feb 09, 2022 5:12 pm
Hi Brian
There is one suggested paint code in the most recent MTFCI judging guidelines. However when I had mine painted a couple years ago and after some research on this forum I ended up with single stage and used a Mercedes Benz dark blue, DB904.
I also like single stage, it can be colour sanded and polished and has been easier to touch up then base clear. And being a regular "commercial" colour, touch up paints are available from various sources too.
The lighting makes a difference in how it looks. The body, fenders and wheels are all the same blue, but in the picture you may see some difference based on light and shadow. It normally looks a bit darker than it appears in the picture.
It was well received at the MTCI 2019 tour on PEI, Canada.
Drive Safe
Jeff
Nova Scotia Canada
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Feb 09, 2022 7:40 pm
Brian-
The midnight blue on my 1911 is the Diamont Uno 4635 color that Les listed above. It is a Mercedes color, DB322, darker than the Mercedes DB409 color that Jeff painted his car.
For comparison, both the other cars are black.
Keith
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Wed Feb 09, 2022 7:58 pm
Here's are links to a couple MTFCA Forum discussions about the "Midnight Blue" paint codes from a few years ago . . . with photos.
http://www.mtfca.com/discus/messages/118802/125711.html
http://www.mtfca.com/discus/messages/33 ... 1357355430
Maybe these will help.
Preserving Mechanical History for Future Generations since 1965
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Thu Feb 10, 2022 10:45 am
I prefer to use a single stage paint, and the color I have used is 1985 Mercedes Benz Dark Blue, Code 904. This is a very dark blue that has a rich tone. This color is identified in the "MTFCI Restoration Guide and Judging Guidelines." My 1913 touring and 1911 Torpedo are this color. I hope this helps. Russ Furstnow, MTFCI Chief Judge
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Post by NorthSouth » Thu Feb 10, 2022 11:22 am
In an effort to mimic Keith Townsend’s 1911 Ford midnight blue, my paint is:
Axalta Centari Acrylic Enamel dark blue Code BS452 with 25% of each gallon being Axalta Centari Acrylic Enamel black Code 99-A . However, I still wanted it even darker so I dumped both gallons of the above mixture into a clean 5 gal bucket and mixed in one additional quart of Axalta Centari Acrylic Enamel black, Code 99-A. This is how I got the rich blue-black that we like.
The fender pic is this “even darker” midnight blue.
The color comparison pic shows before and after I added the final quart of pure black.
