Wow! The cost of the window wood is out of this world. $360, $254, and so on.
I might as well fab my own.
Anyone have the dimensions for the 27 Coupe quarter windows and rear window wood?
27 T Coupe Window Wood Dimensions
daveclause
Topic author - Posts: 147
- First Name: D
- Last Name: R
- Board Member Since: 2004
Re: 27 T Coupe Window Wood Dimensions
Hope someone has the dimensions but you can get a rough idea how it looks from the diagrams from Fordwood. You can use wood pieces and use trial and error to make the pieces to see if you can make it without dimensions. I did that for some trunk pieces for my 24 Coupe. I had some scraps and got them to fit and used ash to make the permanent pieces.
varmint
- First Name: Vernon
- Last Name: Worley
I will try from our Oct 1926 coupe. There is no interior yet.
There are different 26-27 rear and side constructions and I really need to see what style you have.
One of the best options will be to use a cardboard template by tracing the interior of the side windows.
Here are some examples that I found from unobtainium:
Vern (Vieux Carre)
